Soft Top Latch Repair (when Latch doesn't click in anymore)
Postby Cloggy » Sat, 16 Aug 2008 1:45 +0000
Postby mx5ash » Sat, 16 Aug 2008 8:52 +0000
NIce tip that one cloggy one of mine doesn't click properly. Cheers
Postby Steve » Sun, 17 Aug 2008 4:32 +0000
had something similar happen to mine in the past but it was the nub that the catch ..ehh.. catches that had worn down. Some superglue mixed with plastic filings built it up again..
Postby fabfiveferg » Mon, 18 Aug 2008 8:51 +0000
srigley wrote:. Some superglue mixed with plastic filings built it up again..
How the F**k did you come up with that solution?
As it worked I suppose it's genius
Postby Cloggy » Mon, 18 Aug 2008 12:40 +0000
srigley wrote:had something similar happen to mine in the past but it was the nub that the catch ..ehh.. catches that had worn down. Some superglue mixed with plastic filings built it up again..
Jees Steve, I have to check this one out next time I see you. Does it really provide enough strenght?
Postby Steve » Mon, 18 Aug 2008 2:35 +0000
Wish I'd taken some pics of it now... it was on the 1990 I had a couple of years ago.
Basically.. put superglue on the spot you want to build up, sprinkle plastic filings on it.. let it dry.. repeat until it has built up high enough. You can then sand it to shape. I guess you could use JB weld either.. probably easier.. with a bit more drying time but less likely to glue your hand to the table/the car/your eye.
Postby Cloggy » Mon, 18 Aug 2008 8:16 +0000
Great tip; as I tried the above over the weekend end the gap is too big, so I'll definitely try adding something along this line (maybe some solder).
PS did ya check the vid off the red Mk1 on the funnies section?
