NickD wrote:Ok, for those of you will little else to do, you may remember I was thinking of modifying my car seats to accept harnesses.
So I decided to give it a go!
First off, remove the seat, always useful!
Saw the back off and commandeer the kitchen table and upset the woman of the house!
Ok, don't actually saw the back off!
Mark out where you want the harnesses to be. Shoulder height is always a good idea!
Get the knife out, say a prayer, #-o
position the dog ready to kick and ...............
Then pretend you are in the Black Arm of the KKK, don't look like that, times have changed!
Then start cutting
If you are having trouble, get an adult to help you.
That is quite a lump of ear wax!
Do the other side, oh it's so easy now!!!
DO a test fitting.
Add the glue, inhale deeply
And bathe in the glory!
Test fit the other side.
Realise you need to trim some plastic and you need to saw straight, so get out the custom, purpose made jig!
Don't tell the Mrs that the tooth brushes are in danger of loosing their home!
Viola!!! He looks sad doesn't he?
The two halves just need clamping together while the glue dries.
Of course this means I have to drill more holes in bodywork now for the other harnesses!
