Pop up headlights stuck!
Postby Manic » Mon, 23 Mar 2009 10:21 +0000
Hi all
Been a member here a while but this is my first post as unfortunately i have a problem :(
I have a 1990 eunos roadster
Headlights are stuck up this morning! The light is off but I can't seem to get them back down.
Any advice would be really appreciated
Thanks a mil
Manic
Re: Pop up headlights stuck!
Postby Steve » Mon, 23 Mar 2009 11:57 +0000
The button on the dash under the emergency flashers button isn't pressed in by any chance is it? ;-)
Postby Manic » Mon, 23 Mar 2009 12:06 +0000
srigley wrote:The button on the dash under the emergency flashers button isn't pressed in by any chance is it? ;-)
Nope tried that
Manic
Postby Steve » Mon, 23 Mar 2009 1:23 +0000
Did you have your centre console removed anytime recently?
Postby Manic » Mon, 23 Mar 2009 1:32 +0000
srigley wrote:Did you have your centre console removed anytime recently?
Nope
Have done any work to her in a while really
Manic
Postby Steve » Mon, 23 Mar 2009 2:22 +0000
Hmmm... might be the relay..
In the rear right (when looking in from the front) of the engine bay, just inside the "lip" on top of the wing, there is a couple of relays under a black plastic cover. Try tapping them with a screwdriver or similar to see if the lights will move.
Postby Manic » Mon, 23 Mar 2009 2:29 +0000
srigley wrote:Hmmm... might be the relay..
I'll give this a go later
cheers for the advice
Manic
Postby robmx5 » Tue, 24 Mar 2009 8:56 +0000
Is it both lights - possibly fuse ? If its only one then try the black knob in the engine bay - I think you have to remove the fuse first though
Robin
