I got a set of shocks and springs from a member in Cork, only thing is - the rears are Bilsteins, the fronts are OEM.
Do the Bilsteins use lower than standard springs? I need to replace the whole lot, with the minimum of expense. The Ohlins on it are in need of a rebuild, and I can't afford the £80 per shock to have that done at the mo.
