MX5Parts gear lever boot - how long do they last?
Tue, 18 Aug 2009 11:24 +0000
by Reesy
Hi,
I fitted a new gear lever boot upper & lower (like this
http://www.mx5parts.co.uk/product_info. ... ts_id/1111 but mine may not have been OEM parts) six or seven years ago, & I fear they've failed already cos heat is coming thru from underneath round the gearstick.
Before I take it to bits & look, how long do you guys find that the gear boots last?
Simon
Re: MX5Parts gear lever boot - how long do they last?
Wed, 19 Aug 2009 12:13 +0000
I need a new one again now, big hole/split, all sorts of smells coming in from the engine.. right enough, they don't seem to last too long
Wed, 19 Aug 2009 6:44 +0000
by leamyj
When I got my 5 first, the boot was in bits and I drove it for a year before realising it. The one thing I do remember is the fierce amount of heat that rose up through the damaged boot. There was no sound proofing packed around it and you could see the road below as the gaiter wasn't great either. I would assume that the extreme heat from the exhaust is the reason for the deterioration in the rubber.
Wed, 19 Aug 2009 7:58 +0000
by Reesy
Thanks lads - I'll take a look when I get a minute.
Simon
Wed, 19 Aug 2009 6:59 +0000
by MX5Steve
must take a look at mine, felt very warm after a long spin last week, I replaced mine when I got her in Oct 2007 when she had 141000 on the clock so now shes 23K more on the clock..... so if shes gone that should give a good idea of the life of em...
Wed, 19 Aug 2009 11:08 +0000
by Medic5
Ahhhhhh, that explains why I can cook on my gear gator!
Thought it was a unique bling I had
Ok where do I get one?
Thu, 20 Aug 2009 10:50 +0000
by fabfiveferg
Sun, 13 Sep 2009 10:04 +0000
by Reesy
Yep, took a look at mine & both were worn out. Replaced both & also got a leather gaiter from IL Motorsport too. Problem solved, until the next time.
Simon
