Heating
Heating
Postby graham » Sun, 03 Jan 2010 9:33 +0000
I'm having a problem with the heating in the car...
1. It never gets very warm, warm but not warm enough!
2. Cold air comes form the passenger side when I have the heating on, even when the air should be coming out at the windscreen.
I know it's not the thermostat as I only fitted a new one recently.
Any suggestions?
Also it looks like my clutch is on the way out as its revving a bit on acceleration, what parts do I need?
Graham
graham
Re: Heating
Postby sidewaysreilly » Sun, 03 Jan 2010 11:15 +0000
Have the same problem. No heat, just warm air.
Discovered the t-piece leaking on the stat housing so made up a new one. New coolant added and still no heat. Found pin hole in Rad top hose so replaced that. No heat still so brought her out for a spin last night and temp not rising above 1/4 so gonna change stat. If that dont work ill light a fire in the fecker!!!!!!!
Re: Heating
Postby graham » Mon, 04 Jan 2010 12:40 +0000
I changed my thermostat, thermostat housing, new coolant etc in August so all that should be fine, I don't think there are any leaks, the temp dial goes to about half way, I can still get some warm air out of the center vents, but it's just not warm enough.
g
graham
Re: Heating
Postby sidewaysreilly » Mon, 04 Jan 2010 12:43 +0000
yeah, just the same here. I think there may be some special way of bleeding the air out but none of the books recomend anything. HELP !!!!
Re: Heating
Postby Steve » Mon, 04 Jan 2010 2:19 +0000
Tried this ?
Heater cable adjust
Or.. check the hose connection.. remove the glove box (2 screw under the hinge lip, or you could just assume "the position") and check to see if the heater hose is attached correctly, the clips can pop off.
Re: Heating
Postby sidewaysreilly » Mon, 04 Jan 2010 5:10 +0000
Try the section on bleeding the system on here;
http://www.miata.net/garage/CoolingSystemProblems.html
Re: Heating
Postby sidewaysreilly » Mon, 04 Jan 2010 5:39 +0000
this is better, im gonna try it later and report before my goolies fall off!!!!
http://www.mx5oc.co.uk/forum/forums/t/213.aspx
Re: Heating
Postby TeenaG » Tue, 05 Jan 2010 10:55 +0000
FMAO.....? (Freezing My Ass Off) :roll:
TeenaG
Re: Heating
Postby sidewaysreilly » Tue, 05 Jan 2010 1:14 +0000
Didnt work and i'm looking for a welder to attach 2 oval shaped objects to a couple of apes!!!!!
Gettin pissed off with this now, nearly had the fecker standing on the back bumper to get all the air out and still only warm air.All cables working as the should. Stat is all thats left now.
Re: Heating
Postby Steve » Tue, 05 Jan 2010 2:20 +0000
are the hoses going into the firewall behind the head getting hot?
Re: Heating
Postby sidewaysreilly » Tue, 05 Jan 2010 3:45 +0000
untouchably hot!!!!!
Re: Heating
Postby Steve » Tue, 05 Jan 2010 6:36 +0000
so.. it must be an airflow to heater matrix or flap not opening issue.. ?
Re: Heating
Postby robmx5 » Tue, 05 Jan 2010 11:39 +0000
Having the same problem with lack of heat - suspect its since I had the new stereo put in during last summer - so going to investigate behind the glovebox and look at cables/flaps - until then its on with the thermals
Spideog
Re: Heating
Postby sidewaysreilly » Tue, 05 Jan 2010 11:41 +0000
sorted, well sort of????
Got a new stat today and went about fitting this evening to discover........................................... THERE WAS NO FECKIN STAT IN THE FECKER AT ALL. AAAAAAAAAAAARGH !!!!!!!!
Anyway, when i cooled down and the wee gersha warmed up and got all her windies up i went for a spin but thats all i did was spin and spin and spin and grin and grin and grin. Great crack but couldnt go quick enough to really load her up.
Temp thro vents about 18- 20 deg, not great but much better. Temp gauge still showing half so i presume they are not that accurate??????
Re: Heating
Postby CashelMX5 » Tue, 05 Jan 2010 11:53 +0000
Geez Sean your a cold creature - if it's not your head it's the rest of you :mrgreen: :mrgreen: A heated seat might help and you could also get one of them electric teapot cossies for your head :lol: :lol:
