Petrol cap lever is stuck in Mk2
Postby daith11 » Tue, 09 Mar 2010 1:01 +0000
Hi
Inside my MK2 there is the middle compartment between the seats, where you can find the levers for the boot and petrol cap. However the petrol lever has become stuck, it does not move at all. I can open the cap by going into the boot and releasing it manually. However i need to get this problem solved. Has anyone got any advice or is this one for a mechanic?
Cheers
Dave
daith11
Re: Petrol cap lever is stuck in Mk2
Postby charged_rs » Tue, 09 Mar 2010 1:28 +0000
easy fixed
when you lift your petrol flap, you will see towards the back a little black nut.
undo it then remove the washer and pull the cable back into the boot
use loads of silicon spray ( yellow can from halfords) or wd40 would do if thats all you have. spray the little latch that pops in and out. If yours is stuck you might needs to force it to get it going.
put it back together and job done, 20 mins and a bit of lube and its the cheapest fun you will ever have :mrgreen:
try that and see how you get on
Postby leamyj » Tue, 09 Mar 2010 8:04 +0000
"20 mins and a bit of lube and its the cheapest fun you will ever have"
Now where have I heard that before??
Postby TeenaG » Tue, 09 Mar 2010 2:16 +0000
...all of 20 mins huh...? :roll:
TeenaG
Postby barney » Tue, 09 Mar 2010 10:57 +0000
..depends on the lube.... :lol:
Postby sidewaysreilly » Sat, 13 Mar 2010 11:03 +0000
20 mins should get plenty of lube....... :lol: :lol: :lol:
