Alternator Belt
Sat, 14 Jan 2012 1:50 +0000
by graham
My alternator belt has been slipping again, I fit a new one about a 2 months ago. How much should I adjust the belt? I tightened it till it stopped screeching and let the engine run at high revs for a bit and it seems grand now.
I bought one of these
http://www.ebay.com/itm/12V-24V-RED-DIG ... 5ae46e6cf2 to check the voltage, much easier than a multimeter across the batter.
g
Re: Alternator Belt
Sat, 14 Jan 2012 3:08 +0000
by leamyj
That's for nothing! Just bought one , less than €4, delivered
Re: Alternator Belt
Sat, 14 Jan 2012 6:39 +0000
by sidewaysreilly
On any belt, you should be just able to twist it 90 degrees between thumb and finger at the centre point between pulleys on the longest distance.
Re: Alternator Belt
Tue, 17 Jan 2012 12:05 +0000
by graham
Grand, will double check it! It seemed fine last night, was out for a quick spin!
g
Re: Alternator Belt
Sun, 22 Jan 2012 10:46 +0000
by graham
Damn belt is still slipping, how loose does the 14mm bolt at the pivot point need to before I tighten the adjuster?
g
Re: Alternator Belt
Mon, 23 Jan 2012 8:42 +0000
by johnv
i had trouble with belts no matter how many times i adjusted them the still squeeled i bought a set of mazda belts never had a problem since
