loose drivers door mirror
PostPosted: Wed, 02 May 2012 10:32 +0000
by Merlot man
Hello all ,I have a very loose driver's door mirror ,wont stay in its adjusted position. Passenger one is good and tight. Can it be tightened up or does it need to be replaced? Any and all help appreciated.
Brian
Re: loose drivers door mirror
PostPosted: Thu, 03 May 2012 1:33 +0000
If you take it off, I think there is a central bolt that you can tighten up on the bottom side of some of the mirrors (mine at least).
PostPosted: Thu, 03 May 2012 7:07 +0000
by leamyj
You can also get replacement bolt/spring from mx5parts if it's badly corroded.
PostPosted: Thu, 03 May 2012 7:41 +0000
by Merlot man
Thanks for that lads, will take it off this evening.
Brian
