Right guys i am going to have a crack at fitting the diff i got a few weeks ago
I have a 1.6 with a (i assume) normal diff. the one i got is a lsd from a 1.6.
He also gave me the half shafts and drive shafts. Do i need to fit these or can i use the ones that are on the car. does it make any difference to the work involved? ie less to remove?
I have heard a few people mention that a drive shaft should be marked as they are balanced. Whats the deal there should i use the ones that came with the diff??
I know there is a guide on here for swapping a 1.6 to a 1.8. but this is slightly different (and hopefully easy) as its a stright swap.
The new diff is the older style one with the drive shafts attached to the diff by 4 bolts. It looks like a really easy job if i don't need to swap the drive shafts and the prop shaft. (not sure if thats what they are called but you know the one from the gear box and the ones to the wheels)
I'm thinking, exhaust off, prop shaft unbolted and dropped, drive shafts unbolted at diff but stay attached at hub just moved away, ppf off, unbolt diff and drop down. New diff up, reattach drive shafts and prop to diff. ppf and exhaust refitted. fill with oil. Good to go.
Is this right??
Big question is is this possible to do without removing the halfshafts. Do i need to use the propshaft (are they balanced to the diff or something)
Sorry for all the questions but its the only way i can learn.
Thanks Ash
