Page 1 of 2
NCT - Emissions
PostPosted: Fri, 15 Feb 2013 2:10 +0000
by jproneill
Seeking some advice or help .
Recently bought my first MX5 – JDM (Mk2) Spec bought from a sport car specialist dealer in outside Manchester in the UK. Have to admit it may have been love at first sight.
Car went in for NCT last Saturday and failed on top Item :
1) Handbrake imbalance ( New Cable ordered to sort )
2) Emissions ( Were up at 0.7)
Have anyone experienced this before . Car has just been serviced prior to NCT .
1) Is it worth while replace Lambda sensor or will this have any effect .
2) Or take the tradition approach – Hot engine and put a couple of cleaners through it .
Any help appreciated :)
Re: NCT - Emissions
PostPosted: Fri, 15 Feb 2013 8:44 +0000
by hoopsbhoy
Best bet is to post up all the exact readings to give people a better idea. I have failed emissions on literally everything at some point or another since the nct came in.
Re: NCT - Emissions
PostPosted: Sat, 16 Feb 2013 10:57 +0000
by MX5Spares
Inbalance is most likely seized caliper not really cable. Emissions is probably either airflow meter or maybe throttle body.we have all parts if you need them but get it checked out first.Robert 086 8226506
Re: NCT - Emissions
PostPosted: Tue, 19 Feb 2013 12:43 +0000
by sidewaysreilly
post exact results and we can tell whats wrong.
Re: NCT - Emissions
PostPosted: Tue, 19 Feb 2013 1:42 +0000
by jproneill
Thanks Guys - Will post Exact Results this evening
Re: NCT - Emissions
PostPosted: Mon, 25 Feb 2013 10:47 +0000
by jproneill
Results :
Lamdba: 1.00 - Not between 0.97 and 1.03
CO 0.52% VOL - Allowed 0.30%
HC 46ppm - above 200ppm
Thanks again for help .
Re: NCT - Emissions
PostPosted: Mon, 25 Feb 2013 3:29 +0000
by leamyj
Lambda sensor is within range if I'm reading it correctly??
Re: NCT - Emissions
PostPosted: Mon, 25 Feb 2013 4:19 +0000
by jproneill
No its out too - NCT Cert says Not between 0.97 and 1.03 - Mine read at 1.00
Re: NCT - Emissions
PostPosted: Mon, 25 Feb 2013 7:37 +0000
by leamyj
jproneill wrote:No its out too - NCT Cert says Not between 0.97 and 1.03 - Mine read at 1.00
Now I'm confused..in my reading of this, your reading of 1.00 is EXACTLY midway between 0.97 and 1.30??? What am I missing here?? :shock:
Re: NCT - Emissions
PostPosted: Mon, 25 Feb 2013 7:50 +0000
by hoopsbhoy
Lambda is a fail if is NOT between those figures, so yours is spot on.
Have you got your timing advanced?
Re: NCT - Emissions
PostPosted: Tue, 26 Feb 2013 2:52 +0000
by sidewaysreilly
Engine is running rich, replace air filter and/or oxygen sensor.
Give it a good hard drive to burn off excess carbon and see will it pass. If not, o2 sensor or a bunged up cat.
Re: NCT - Emissions
PostPosted: Tue, 26 Feb 2013 12:40 +0000
by jproneill
Cheers for the advice
Car has just been servived - so air filter is a Brand new .
Just looking at the internet at the Oxygen sensor on the net and there seems to be literally hundreds of different Types.
Is there one in particular I should get - would a secound hand one do the trick ... ?
Re: NCT - Emissions
PostPosted: Tue, 26 Feb 2013 1:47 +0000
by sidewaysreilly
You will need the correct one for your engine. Check out mx5parts for one.
Re: NCT - Emissions
PostPosted: Fri, 11 Oct 2013 4:19 +0000
by jproneill
Bit late on updating this Post - Problem was the CAT - If it helps aanyone else
Re: NCT - Emissions
PostPosted: Sun, 13 Oct 2013 8:46 +0000
by Merlot man
Try Robert in Dublin for a good second hand one , his no will be in the for sale secton
Brian
