Breaking for parts: UK-spec 1.8 1996 red mk1
Postby franksm » Tue, 01 Sep 2015 9:44 +0000
All located in Lucan, Co. Dublin.
Dash (black): €30
Wings : €70 - passenger side has one small ding and a couple of scratches; driver's side is perfect. Both in red.
Front bumper €30 (red, faded, would need painted)
Front number plate plinth €20
Hardtop mounting plates and Frankenstein bolts €30
Rear bumper : €10 (red, faded, would need painted - has two cutouts for dual-exhaust)
Bonnet: €30 (red, faded)
Door card: €30 each (black and with aftermarket pockets)
leatherette pocket for zip-down window €20 (sits on rear deck and receives plastic window like an envelope, protects it when zipped down)
small leatherette storage pocket €20 (sits behind the seats, attached to the vertical carpet)
ashtray (never used) €10
rear light unit €20 each
front light unit (takes H4 bulb) €20 each
front light metalwork and plastic bowl €20 each
UK rear number plate panel €60 (red)
radio panel €20
eyeball vents €5 each
headlamp motors €15 each
pair of crystal front indicator units €50 http://www.mx5parts.co.uk/front-indicat ... p-942.html
standard 1.8 underbody chassis frames €20
differential, 1.8 1996 model open diff and carrier €140
engine, 140,000 miles on it (70K of it was turbo'd). In good condition but head is separated from block (to assist turbo removal) so would need head gasket and timing belt. Water pump has 400 miles on it. €120
driver's door with mirror and glass, €40 (perfect condition, red)
passenger door with mirror and glass, €20 (paint is faded badly, window glass is scratched badly)
door locks and latches €40 for the set
1.8 1996 ECU (OBD2 version), €60
1.8 air-flow-meter AFM €40
Momo champion steering wheel and boss €100
standard 1.8 air intake €10
seats €40 (black, separate headrests - passenger seat is perfect, driver's seat has worn bolster)
dash clocks and binnacle €30 (Perfect condition, UK spec 1.8, in mph and kph, showing 140,000 miles)
leather gearstick gaiter €15 (perfect condition, black)
boot lid, €10 (red, faded, slight dent)
spacesaver spare wheel €10
Black OEM tonneau cover (for the rear deck) €25
Brand new unused trackrod end €15 (http://www.mx5parts.co.uk/track-afterma ... p-555.html)
New and unused clutch slave cylinder (I have two of these): €15 each http://www.mx5parts.co.uk/clutch-slave- ... p-252.html
Thermostat €5 (no gasket) http://www.mx5parts.co.uk/thermostat-af ... p-247.html
Rear lamp gaskets, genuine Mazda, unused and still in packets €10 each http://www.mx5parts.co.uk/rear-lamp-gas ... -1415.html
Re: Breaking for parts: UK-spec 1.8 1996 red mk1
Postby tiggerl82 » Tue, 01 Sep 2015 9:51 +0000
Hi, how r u!
My mx5 back on the road I might need a few bits and pieces.
I am interested in the steering wheel! What is the diameter? You have a picture?
Mazda Eunos Roadster B2 Limited
tiggerl82
Postby franksm » Tue, 01 Sep 2015 9:57 +0000
Hi Tigger, it is 35cm diameter. I don't have an actual pic of it here (yet) but you can see it on this link. It is in perfect condition and is half leather, half suede
http://www.miata.net/products/ptm/ptm9706.html
Postby tiggerl82 » Tue, 01 Sep 2015 10:03 +0000
Is it comin with the adaptor? My car was off the road for more than a year, and the steering wheel falling apart... The outer layer coming off.
Do u have the gear knob as well?
tiggerl82
Postby franksm » Tue, 01 Sep 2015 10:40 +0000
Not sure if I still have the original gear knob, I'll check what's in the boot tomorrow. I had a "Voodoo knob" fitted since early on, but I'll keep that as a souvenir :-)
Yes, the steering wheel comes with the hub adaptor, a rubber cover and also the horn button. Everything you need really
Postby Stuart1 » Tue, 01 Sep 2015 11:21 +0000
Need a few interior bits:
- ashtray
- blanking plates for dash - visible when doors opened
- plastic door stop (passenger side)
- plate that hides the wires under steering wheel (?name - sits under steering cowl)
Also needed:
- front wheel arch liners and mounting screws/clips
Can collect at the weekend.
Stuart1
Postby franksm » Wed, 02 Sep 2015 9:19 +0000
Hi Stuart, I will have a go at pulling those over the next couple of days. The interior bits are all there for sure. I am away next week, so if Friday doesn't work out, it'll have to be after 14-Sep
Postby franksm » Fri, 04 Sep 2015 5:34 +0000
Alright lads, car is going to Robert (Autocheck) apart from the items which some of you expressed interest in (Stuart - ashtray, blanking plates for dash, plastic door stop, dash knee panel; Tigger - steering wheel and boss; Steve - roof; Steve's mate - seats)
Couple of interesting items on the car that you can ask Robert about: there is an ACT Flyin' Miata turbo clutch fitted; 5-speed gearbox and rear open diff are all good; front wings are good; engine is good but was disassembled; lamps, motors, etc all good; UK rear panel, front crystal indicators. The car has adjustable KYB AGX shocks with 30,000 miles on them plus Koni springs - nice low ride, but not harsh at all; A-arms are all polybushed Powerflex) - Steve's name is on the suspension bits.
I still have the Rota wheels & new tyres (Avon ZZ3 215x40xZR16) if anyone is interested
