As above its for a megasquirt project in another car so mk1 or mk2 version will do. Must be willing to post.
throttle position sensor and plugAs above its for a megasquirt project in another car so mk1 or mk2 version will do. Must be willing to post.
Re: throttle position sensor and plugHey John,
You probably want a sensor and plug from a 1.8/MK2 engine, as the 1.6/MK1 version is only a full throttle switch, not a variable TPS (unless it's from the automatic model). What engine do you have? If it's a 1.6 you can install a TPS from a BMW, you'd need Rhysmate to make you an adapter plate. Best of luck! Nico
Re: throttle position sensor and plugWe have some here 086 8226506
