Page 1 of 2
Failed Nct
PostPosted: Tue, 11 Sep 2012 8:15 +0000
by fierymx5
Any one got a set of cheap rims with decent tyres just need em to pass Nct apparently my wheels are too wide (load of shite) any thing considered thanks lads
Wayne
Re: Failed Nct
PostPosted: Tue, 11 Sep 2012 9:23 +0000
by kieran
whats your location
Failed Nct
PostPosted: Tue, 11 Sep 2012 10:18 +0000
by fierymx5
Based in graiguenamanagh co Kilkenny but am in the city nearly everyday
Re: Failed Nct
PostPosted: Tue, 11 Sep 2012 10:22 +0000
by kieran
too far away id give u a loan of a set
Failed Nct
PostPosted: Tue, 11 Sep 2012 10:29 +0000
by fierymx5
No panic Kieran thanks for the offer tho
Re: Failed Nct
PostPosted: Tue, 11 Sep 2012 10:31 +0000
by rhysmate
Why were they too wide? Tread sticking out?.
Failed Nct
PostPosted: Wed, 12 Sep 2012 7:45 +0000
by fierymx5
No that's what I thought as well but the thread is clearly under the arch.the tyre might be a little stretched but the rim sticks out a bit il upload a photo later haven't got any on the phone at the moment. Went looking in the Nct manual last night and can't find anything about failing because the tyres are too wide wudnt mind but my fronts are just as big and it's only the back he has a problem with
Failed Nct
PostPosted: Wed, 12 Sep 2012 7:46 +0000
by fierymx5
Failed Nct
PostPosted: Wed, 12 Sep 2012 11:06 +0000
by fierymx5
Best pic I could find of the rear Image
Re: Failed Nct
PostPosted: Thu, 13 Sep 2012 11:07 +0000
by scallan
mine are simmilar and didnt have a problem with n.c.t
Failed Nct
PostPosted: Thu, 13 Sep 2012 12:43 +0000
by fierymx5
I'm so pissed off with em they said all four shocks were loose as well.but yet when I looked this morin their all ok. I think when he raises the car the springs drop down because the cars lowered and they look like their loose on the coilover my heads in a heap trying to sort all the crap from em thinking might try test it in another centre Image
Image I don't think they really stick out that much
Re: Failed Nct
PostPosted: Thu, 13 Sep 2012 2:23 +0000
by scallan
no they aint last time i tested mine i had 15x8 et 10 on the back and 15x6 et38 on the front no problem but ya i found the test centre in arklow alot better than enniscorthy
Re: Failed Nct
PostPosted: Fri, 14 Sep 2012 7:00 +0000
by leamyj
are the NCT not required to explain to you EXACTLY why they fail a vehicle???
Failed Nct
PostPosted: Fri, 14 Sep 2012 8:29 +0000
by fierymx5
Yea the problem with the wheels are they stick out to much.he the told me all the springs were loose on the car but I went around em all yesterday and cudnt find a problem wit them at all . Wudnt mind when I removed the two back wheels the inside of them were nearly bald from the camber in the car and the sidewall was cracking and he never even seen that
Re: Failed Nct
PostPosted: Fri, 14 Sep 2012 8:37 +0000
by rhysmate
they will fail you if the springs are loose when the car is up anywhere man.. just wind the adjusters up until the springs are tight and get a set of standard wheels from somewhere. they can be your ''nct wheel''.. i know a man in limerick who has loads of standard wheels with tyres
