Wanted: Machining work done
Postby motthomas » Mon, 27 Jan 2014 11:54 +0000
Hi lads. I'm looking to get some machining work done for one of my motorbike projects and was wondering if any of you lads have ever got anything done for the car or know of anyone that could do it.
The story is that I'm in the final stages of converting a CBR250RR to EFI and need some machining work done on a set of carbs converted to throttle bodies. Link the the project here: http://projectcbr250rri.blogspot.ie/
I need injector seats bored into each of the individual bores so that drilling would start at a 30 degree angle to the first flat surface. Three sizes of holes will need to be drilled/bored to accommodate the injectors. The first to allow for the injector tip, the second bored to allow the injector to seal against the carb body and the third to allow for the wider part of the injector to fit.
I also have an injector rail which also needs to be drilled and bored to accommodate injectors and tapped and face-cut at either end to allow fuel fittings to seal.
So far I have approached some smaller machining firms in Dublin with the work but they seem unwilling to take it on as they see it as not being worth their time. Ideally what I am looking for is somebody who does machining as part of a hobby and who would have the equipment and the interest in a project like this. A manual milling machine and small lathe should be sufficient to do this type of work. I have drawings to share and am more than willing to spend time talking through the project with anyone willing to give it a go. Anyone who is willing to take it on would of course be paid for their time. I am not looking for a free lunch here.
Do any of you know somebody that would have the equipment and interest to take this on? Maybe a friend or someone you have dealt with previously? I have a preference for someone around Dublin but I am willing to travel to get this done. Let me know and any nudge towards the right direction would be very much appreciated!
Thank you.
motthomas
Users browsing this forum: No registered users and 24 guests
