Coolant rubber pipe
Coolant rubber pipe
Postby BAwagon » Wed, 24 Jun 2015 7:20 +0000
Got home last night after some great driving around Lough Ree and ass soon as I stopped the engine I could smell that I have a problem.Coolant leak. Thankfully it`s not too bad just a short rubber pipe burst. It`s the one is hiding behind water pump belt pulley. It`s very close to the belt so probably can`t use anything else but OEM part. Have You any idea where where to get one?
BAwagon
Re: Coolant rubber pipe
Postby Steve » Wed, 24 Jun 2015 9:44 +0000
Postby BAwagon » Wed, 24 Jun 2015 11:12 +0000
Brilliant! Thx! Looks the same but it says mk1. Mine is a 99 nb. But it looks identical.
BAwagon
Postby MX5Spares » Wed, 24 Jun 2015 5:40 +0000
They are the same. Its only the mk2.5 has larger bore hose/fittings,maybe 10mm approx
