mk1 ignition barrel
PostPosted: Mon, 09 Nov 2015 3:18 +0000
by Real Rayzor
Hi all.. I'm looking for an ignition barrel, door/boot locks for a 92 mk1 eunos. please pm me if anyone has lying around in their shed.
Thanks Ray
P.S. if you have the glove box and centre console locks as well that would be an added bonus
Re: mk1 ignition barrel
PostPosted: Mon, 09 Nov 2015 6:15 +0000
by MX5Spares
Hi Ray we should have most of the bits 086 8226506 .Two types of igntion switches and they will not interchange.
PostPosted: Mon, 09 Nov 2015 7:58 +0000
by Real Rayzor
Thanks Rob.. thought you would have them but I'm trying to get local because I don't think I'll be up your way for a while. If I can't get them down here I'll get back to you.
PostPosted: Mon, 09 Nov 2015 8:01 +0000
by MX5Spares
We can post down
PostPosted: Mon, 09 Nov 2015 10:16 +0000
by Real Rayzor
autocheck wrote:Hi Ray we should have most of the bits 086 8226506 .Two types of igntion switches and they will not interchange.
I think the barrel I need is the one without the wings if you understand what I mean. here is a picture of the damaged ignition in the car. can you tell which one it is.
PostPosted: Mon, 09 Nov 2015 11:08 +0000
by MX5Spares
Yes I know the one.Do you need the plastic cowlings around the lock also?
PostPosted: Tue, 10 Nov 2015 12:12 +0000
by Real Rayzor
:shock: No. surprisingly they were not damaged
PostPosted: Tue, 10 Nov 2015 7:34 +0000
by MX5Spares
Ok we have the lock then. 086 8226506. Just a second thought if cowlings are nor broken then most likely the screw holders ( where cowlings screw on0 will be broken out of the wiper/indicator switches.Unless they had philipps screrwdriver and removed screws......unlikely? Mock up the cowlings to switches and confirm that the screw holes are still intact
PostPosted: Tue, 10 Nov 2015 9:16 +0000
by Real Rayzor
Looks OK Robert. No need for any cowling. Can you text me or pm me on a price for the ignition barrel , doors, boot, glove box and center console locks.
Cheers Ray o879156o73
PostPosted: Wed, 11 Nov 2015 8:06 +0000
by MX5Spares
PM sent
