Users browsing this forum: No registered users and 24 guests
Thermo housingAnyone got the inner section of thermo housing for early 1.6. (the long neck section that bolts to the head and has small T piece off it for hoses).I have few here on good engines , and I have several 1.8 ones (different) but I need early type from mx5 1.6 up to 1993/4.I have the top section with the fan switch attached .I dont want to strip good engine to remove this piece (means timing belt, cam pulleys etc off etc and this only makes nore work for me and customer when buying engine from me.)
Re: Thermo housingI think I've got a spare one of those, I'll check tomorrow
![]() Re: Thermo housingGood man ,as I say I dont want strip engine just for the housing.Check to 2 small outlets as they rust badly.Thats whats wrong with the one my customer has.I have mk2 ones but pipes are bigger diamater. Thanks
![]() Re: Thermo housingThats the one alright.Are the two small pipes ok. A lad in Cobh is looking for it.Whats your number and I can get him to collect from you.I will pay you if you give me your paypal acount. He gets bits from me but I only had incorrect type for him so I owe him it basically. Thanks
Re: Thermo housingAh sure I'm in Douglas, just a ferry away from Cobh
![]() The two little pipes have no surface rust and none of the normal heavy corrosion/breaking/brittle etc, it just needs a little clean up to remove the old gaskets and it's 100% as new. You already have my number in your mobile Robert but I'll text you it again just to be sure and you can keep the payment in your head as I'll probably get a few parts from you again at some stage ![]()
![]() Re: Thermo housingGood man and thanks.He is stuck for it but I dont seem to have your number ?
Re: Thermo housingSorry Rob, I was out all day on the road looking at cars and I only got back right now (sister got herself an Audi TT 225BHP!).
Texting you it right now.
![]() Re: Thermo housingTop marks and thanks
Who is onlineUsers browsing this forum: No registered users and 24 guests | ||
