F/€king van driverI was driving my rs to ballincollig today at lunch time to collect something for my brother and as I was just going into a bad bend a van comes around the bend lifting and in the middle of the road leaving me with two choices- hit him and right off my car or hit the wall on the left (there was no run off just a wall off the road), I hit the wall and kept thumping off it until I came to a stop, thought I was after wrecking the whole side of the car but thankfully it was just the alloy that got all the damage, it's in bits
Re: F/€king van driver![]() 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: F/€king van driverSo sorry to hear that Keiran, main thing is you are ok , just think what might have happened and the poor car can hopefully sorted without too much expense.
Re: F/€king van driverI know, got some fright, waiting for the bang, knew I wasn't going to fit between the van and wall, I'm going to have some job trying to find one of them wheels
Re: F/€king van driverOuch! Sounds like you were v.lucky!
Check out this link : http://www.ebay.de/sch/i.html?_from=R40 ... Categories www.Wheels.ie also have them in black but worth asking about others. http://wheels.ie/wheel-details.aspx?ID=1459
Thanks Steve, how do I change the language to English? there used to be an easy way to do it on the laptop but I'm not sure how to do it on the iPad 1990 Eunos Roadster 1.6: cusco coilovers, carbing front and rear strut braces, 1.8 brakes, performance engine and diff mounts, stage 2 cerametalic 6 puck 1.8 clutch with lightweight JUN 1.8 flywheel, 1.8 LSD, GReddy manifold, Garrett T25 turbo, ARTech down pipe, E-Manage blue ecu, Altezza injectors, FMIC. Zoom engineering center console, carbon fibre bonnet, garage vary front lip, lightweight garage hundred one hardtop, carbing 6 pt cage.
Re: F/€king van driverSounds like a really close one kieran! Do you think the van driver knew what happend? Hope you can get a wheel handy enough.
Re: F/€king van driverLady luck was smiling on you Kieran, glad you weren't hurt.
Re: F/€king van driverGlad you were not hurt. Hope you can get sorted ok and not too much damage.
JohnC
Try this : http://translate.google.com/translate?s ... es&act=url
