A German is trying to invade my Japanese territory
Re: A German is trying to invade my Japanese territory
Postby 93 Mk1 » Wed, 19 Jun 2019 8:55 +0000
Pops wrote:It’s a nuisance having to buy a tool that will only be used once in a blue moon especially when there’s 40 years worth of tools in the shed, anyway this one is for most German cars so as one of my sons has a golf it may well get some more use ( if I ever get round to service it)
Did a bit of work on the rusty arches, just used the grinder with a wire brush attachment for now so that I could put on some kurust rust converter
Pics of two of them, the others are very much the same
The wheels are on the list for repaint as they look much worse than in the pictures
It looks like you have got loads done to it recently. Well done !
As for the drive, I'm not surprised. There were designed to be more like a GT type car rather than our sharp steering MX's. The Audi TT is another that comes to mind.
Postby Pops » Mon, 24 Jun 2019 4:42 +0000
Got a bit further on the rust issues, lots of surface rust but nothing has fully perforated the arches yet. I’ve previously ground back and treated the affected areas and so far it’s pretty solid. My intention was to do a full respray but as I’ve (probably stupidly)declared the 5 off the road from the end of the month I’m only going to repair the arches and blend in the paint for now
Pics of some of the work done, only brushed on the primer as it was getting late, has since been sanded down and sprayed properly with primer
While waiting for the threat of thunderstorms to clear I’ll leave the painting for a few days, I can always make a start on the wheels in the shed
Pics don’t show how bad the wheels really are
New set of center caps already ordered, they’re on the usual slow boat
Postby mrges » Mon, 24 Jun 2019 7:28 +0000
All those 'little' jobs will defo pay off. The wheels don't look too bad, but a set of clean wheels can set a car off really well.
Postby Pops » Tue, 25 Jun 2019 11:58 +0000
Ya, all the little jobs help pass the time instead of hours in front of the tv.
The slow boat from China wasn’t that slow after all ( probably because they were air mailed), new center caps, lightest of plastic as possible but they’ll do the job
Postby Pops » Wed, 26 Jun 2019 10:36 +0000
Finished the rust repair this evening so had to bring it for a test drive
The view of Galway bay
Paintwork isn’t great, painted it outside on Tuesday and I’d say it was too warm so the results were poor enough, color is ok but pretty dull
Postby 93 Mk1 » Thu, 27 Jun 2019 8:45 +0000
Looks fine in the pics Pops ! You live in a nice part of the country it seems :)
Postby Pops » Thu, 27 Jun 2019 12:21 +0000
Pic is from the Moycullen to Spiddal road, about 12 miles from me, a nice view looking toward the bay and the Clare hills, unfortunately if you look in the opposite direction the first thing to catch your eye is the windmills.
Ran short of compound when doing it so tried to spare it enough to get the car done, getting more today and some proper polishing head and polish, that should fix it
Postby mrges » Tue, 02 Jul 2019 8:49 +0000
Not sure if this job is on your horizon, Pops, but I spotted this in last months 'Classics' magazine.
Postby Steve » Tue, 02 Jul 2019 10:05 +0000
Any updates? :-)
Postby Pops » Tue, 02 Jul 2019 1:40 +0000
Thanks for that mrges, hadn’t thought of it but will certainly check it.
Updates Steve, as recommended always read the label, I bought the black paint and the wheel paint at the same time but haven’t yet done the wheels, when I went back to get the compound I mentioned how the black turned out, I suppose it was a lack of communication or lack of recent experience but I didn’t realize that it was a base coat, I was under the impression that it was a single pack paint suitable to blow in the repair, anyway it proves that you can polish a turd. I’m now the proud owner of another 1/4liter of base coat and a liter of lacquer & the hardener , the wheel paint is also a base coat so I’ll make good use of it
Postby Pops » Tue, 02 Jul 2019 3:38 +0000
Well mrges, good tip there about the cabin filter
Will need a new filter and I think maybe try to clean out the ducts, another job to add to the list
Postby Pops » Tue, 16 Jul 2019 6:25 +0000
On the subject of filters, I was having a problem with the car going in and out of limp mode, usually a p0170 code, fuel trim bank 1, seems there’s many causes of this ,,, maf (already replaced) vacuum leaks ( found 1) o2 sensor is another but I left it alone and kept getting stored or pending p0170 after every drive. So, as the car was poorly maintained I thought I’d change the fuel filter, success, engine idle is good and smooth and power seems much better, old filter was the original I’d say
It was a clean basin when I started
The fuel that came out of the filter, god only knows what the inside of the fuel tank is like
Short trip of about 18 miles, car drives much better and no fault codes or limp mode,,, so far
Postby Steve » Tue, 16 Jul 2019 11:45 +0000
Nice!
Postby Pops » Tue, 23 Jul 2019 3:26 +0000
Got around to doing a bit of touch up on the dash
Before
After
Not bad result really, takes the bad look off it if nothing else
Cheapest I could find on eBay, haven’t done the seats yet
Postby Pops » Tue, 23 Jul 2019 6:20 +0000
Looking back at the “after “ pictures, it needs another coat or two on the glove box
