Anti roll bar question?
Postby Richie L » Sun, 14 Feb 2010 7:03 +0000
I am on a suspension quest this weekend and I noticed today that my rear anti roll bar is not centered..ie the lhs droplink is more vertical than the rhs.I was able to move it by gently tapping with a hammer and my question is should I be able to do this?Do the bushings and droplinks not normally keep the bar from moving in this lateral direction?Or do I have knackered bushings as there is quite a bit of lean from the rear anyway.Any thoughts please?
Richie L
Re: Anti roll bar question?
Postby sidewaysreilly » Sun, 14 Feb 2010 7:33 +0000
chances are Richie the suspension has settled on one side more than the other........rhs???? and also there is probably more wear in the lhs susp and roll bar bushings/drop links due to our roads . I think our one is the same. If that is the case you may be well advised to get the poly bushes before you go getting the re-align done. Try energy suspension in the states for a quote. The young lad got a full set for his Civic Coupe over and all for 150e and the quality is excellent. I will be looking into getting a set also as im gonna put a set of fully adj shocks on her soon.Let us know if you do try them.
[web_site]
http://www.energysuspension.com/product ... -Sets.html[/web_site]
Postby Richie L » Sun, 14 Feb 2010 9:02 +0000
Willdo thanks for the tip Sean :)
Richie L
