fog light for jap mx5
Postby dabofoppo » Tue, 06 Jul 2010 11:13 +0000
new owner here :D
bought an mk2 mx5 rs last week, and the NCT is due in a few months time. i know the NCT are now checking for rear fog lights (they didn't do this before), and i don't think my MX has any. what's the best solution here?
should i convert the rear light clusters to UK/IE ones?
or are there any aftermarket lights that look semi-decent?#
all advice appreciated...
dabofoppo
Re: fog light for jap mx5
Postby Steve » Tue, 06 Jul 2010 11:32 +0000
Howdy,
Welcome to the forum!
The stipulation is that a fog light needs to be working if one is fitted (not that one must be fitted).
From the NCT manual :
"REAR FOG LAMP(S)
Method of Testing
1. If the vehicle is fitted with a Rear Fog Lamp, check that when in use, it provides a red light which is clearly visible.
2. Check that the fog lamp is securely mounted.
3. If fitted, check operation of fog lamp indicator."
Cheers
Postby dabofoppo » Tue, 06 Jul 2010 11:46 +0000
but then on the same page:
REASONS FOR FAILURE
Rear fog light: Missing or not clearly visible.
dabofoppo
Postby Steve » Tue, 06 Jul 2010 12:02 +0000
heheh you can argue that it can't be missing if it wasn't there in the first place ;-)
Postby dabofoppo » Tue, 06 Jul 2010 2:03 +0000
it aint due for the NCT until october (i think), but when the time comes, i'll probably just put it through and see what they say...
thanks for the help
dabofoppo
Postby TOM 5252 » Tue, 06 Jul 2010 8:48 +0000
Whatever about getting through the test, remember it is dangerous to be driving in this country without a rear fog light that you can turn on in bad visibility conditions even when there is no fog about. Last Sunday near midday on the M2 on the way to the Terenure show, the rain was so heavy that I could hardly see the cars in front of me. Except for the few with their rear fog lights on.
And of course when you run into real fog you will (or at least should) feel very vunerable to someone badly damaging your back end by braking too late because they didn't know you were there.
TOM 5252
Postby dabofoppo » Tue, 06 Jul 2010 9:03 +0000
indeed. so what's the best course of action?
should i get a UK cluster, or has anyone ever seen a nice looking aftermarket fog light?
dabofoppo
Postby Steve » Tue, 06 Jul 2010 9:50 +0000
I guess you could convert the driver's side reverse light with a red LED bulb or this looks good :
http://www.mx-5.de/html/peugeot_nsl_in_na.html
Postby johnv » Wed, 07 Jul 2010 7:33 +0000
when i got my car there was a fog light fitted i think it is off an old fiesta
johnv
Postby barney » Wed, 07 Jul 2010 10:12 +0000
the brake light on my mk1's bootlid has been converted to a fog light and passed the nct without any problem.
