CB Radio
PostPosted: Thu, 10 May 2012 4:41 +0000
by goseatonio
As you know, we're planning a long trip arround Ireland this summer. We use to use walkies, but their range is too short, so we're thinking in buying CB Radios.
What's your experience with them?
It's neccesary to do some installation (holes, wiring...) or not?
Re: CB Radio
PostPosted: Thu, 10 May 2012 6:40 +0000
by CashelMX5
HI,
Leamyj should be able to help with CB's as he and other members have used them on trips to Spain and the ring. I'm sure he'd respond to a pm message.
Re: CB Radio
PostPosted: Thu, 10 May 2012 8:57 +0000
by leamyj
Thanks Tom..I think.. :mrgreen:
Yeah, we used them on the two continental trips, very handy. Paschal and I were using them on a charity run two weeks ago.
There is no need to drill any holes. The radios usually come with a cigar lighter attachment for power to the radio and the aerial can be fitted to a magnetic base which can be removed in an instant. here are some ebay links
http://www.ebay.ie/itm/NEW-COBRA-19DX-I ... 882wt_1185
If you want to mount your cb permanently in the dash, you could use one of these:
http://www.ebay.ie/itm/Radio-CB-DIN-Mou ... 507wt_1185
Be sure to purchase a cb that has all the European frequency options as well as the am/fm option
Some sellers will also include your aerial/antenna at a special price.
Good luck!!!
Re: CB Radio
PostPosted: Fri, 11 May 2012 1:28 +0000
John, do you still have a number for the guy you bought yours from?
Re: CB Radio
PostPosted: Fri, 11 May 2012 1:53 +0000
by leamyj
Steve wrote:John, do you still have a number for the guy you bought yours from?
I never did have his number, I do remember his name as Wayne...didn't someone else on here make contact with him since the initial group buy??
Edit:
Yep, just did a search, Cloggy appears to be the last person who was in contact with him, if not Paschal, they may be able to help with his number??
Re: CB Radio
PostPosted: Sat, 12 May 2012 4:24 +0000
by goseatonio
Thank you for the info, I think a CB Radio is a good idea for a long trip.
What's the average distance it can cover in normal situations?
Re: CB Radio
PostPosted: Sat, 12 May 2012 4:57 +0000
by leamyj
goseatonio wrote:Thank you for the info, I think a CB Radio is a good idea for a long trip.
The radios are regulated to a max of 4 watt output. Straight line, on FM, maybe 2 kilometres, but quality will reduce the further apart you are. When we went to Barcelona last year we always had the mobile phone option to compensate for when the group got split up beyond the range of the cb's. Still, they are a cheap way of keeping in touch.
Re: CB Radio
PostPosted: Sat, 12 May 2012 10:04 +0000
by goseatonio
Thank you John,
The question about móvil phones is that spanish conmanies charge huge rates when using outside, so another posibility we're thinking about is buying cheap irish cell phones when arriving to Ireland... :roll:
