by franksm » Fri, 25 Jun 2010 10:35 +0000
I don't get it... does that mean that Japanese imports have different ECUs to rest-of-world cars ? That LED code-reader on my Irish '96 didn't work due to the OBD2 thing.
These are the articles I am going by:
http://www.miata.net/garage/Engine_Diagnostics.html
"Note that this may not work for models newer than 1995 (OBD-II)"
http://www.miata.net/garage/obdii.html
"Mazda Specific OBDII Trouble Codes"
"These codes are as of 12/04, so they should apply to all '96 -'05 Mazdas. Trouble codes less than 1000 are generic OBDII codes and apply to all OBDII compliant vehicles as a minimum Federal Standard. It should be noted that in '08 all manufacturers will be required to move to the CAN protocol, and movement has already started in that direction. For example, the Mazda 6 and RX-8 are already using CAN. This means that scanners previously used for OBDII likely will not work in these vehicles."
http://www.miata.net/garage/faultcodes.html
"Note that the following codes are for '93 and older models. Beginning in '96, the Miata used OBD (On-board diagnostics) which requires a special scanner to read the codes"
