There is
NO difference between the 1.6 Eunos/Mx5 with major parts & fitting them - the only difference is with the '
cowboy price' of fixing it if it's a Eunos
We've had this same old crap with
Mazda Ireland concerning Mk1 parts for years.
A Mk1 is a Mk1 - if there is a difference with the clutch then that car has been 'seriously modded' for a turbo/super charger and it can only be 'upgraded' for that reason
I've said this time and time before, for years - If the mechanic doesn't know the
NON-DIFFERENCE between a 1.6 Mx5/Eunos Roadster then he is either not qualified to do mechanical work on one or is simply scamming you for more money.
In this case concerning the clutch if the mechanic states that there may be a difference between the 1.6 Mx5/Eunos, then chances are he doesn't even know the torque settings for all the bolts between the engine and the trans, or even the clutch plate itself, he probably doesn't even know how to split the engine from the trans to get at the clutch itself. I'd run a mile and so would a lot of other guys on this forum because we've seen this type of carry-on for over 10 years
