Adj cam ????
Adj cam ????
Postby Doc mx5 » Thu, 15 Mar 2012 11:39 +0000
Hi.i was told by the previous owner that my car had an adj cam in it.anyone ever her of it.and how do i adjust it.its a 94 1.8
thanks
Doc mx5
Re: Adj cam ????
Postby LightningMxQueen » Sat, 31 Mar 2012 7:57 +0000
Doc mx5 wrote:Hi.i was told by the previous owner that my car had an adj cam in it.anyone ever her of it.and how do i adjust it.its a 94 1.8
thanks
Hi, your car has two cams one for inlet and one for exhaust, am guessing it might be fitted with adjustable vernier camwheels like this one which I built for a guy in Cardiff:
We also fitted the engine with 2 exhaust cams instead of one of each (see link to [link2http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDQQFjAB&url=http%3A%2F%2Fwww.diymiata.net%2F%3Fp%3D295&ei=TFF3T-HtNIKphAeAgtmXDQ&usg=AFQjCNEyj0JFudBlqXb3UZB9MWG7CMQIXQ&sig2=bb8ISecWriYqaWecmEOOQw][/link2]exhintake mod)
The reason for cutting the cam-cover away to reveal the adjustable camwheels is to allow access for adjustment which is best done while at a rolling road dyno. We obtained a full 10% increase in torque and about 9-10BHP increase @ 13 degrees ign timing.
Although it is possible that the previous owner put a standard cam cover back on to make it look standard the insurance or just to prevent debris getting into the cambelt area.
You would need to remove the cam cover (new gasket and ht silicone and CAS O ring advised when re-fitting) to check what is fitted, look carefully at the very back of the camshaft on the intake side to see if it looks like it has had the CAS drive chopped off, if it has it may have had the exhintake mod carried out.
Irish/Welsh but dont hold it against me ......
LightningMxQueen
Re: Adj cam ????
Postby Doc mx5 » Sat, 31 Mar 2012 8:11 +0000
Cheers for the reply.i posted this ad twice by mistake.iv got alot of responses to the other post.iv also added some pics.maybe u can have a look and c ahat u think.the lads on here reccomended that i putan orignal one back on
Doc mx5
Re: Adj cam ????
Postby LightningMxQueen » Sat, 31 Mar 2012 8:40 +0000
Doc mx5 wrote:Cheers for the reply.i posted this ad twice by mistake.iv got alot of responses to the other post.iv also added some pics.maybe u can have a look and c ahat u think.the lads on here reccomended that i putan orignal one back on
Ahhha! Found your other thread, its up to you but I would have a look to see if your inlet cam is actually a cut-down exhaust cam first, as the exhintake mod is a good enhancement as the exhaust cam does have more duration even if the actual valve lift is identical to the intake cam (only works with 1.8) but with a standard cam cover it would be a pain to adjust the cam timing at the dyno but the gain could well be worthwhile if it was set-up properly.
LightningMxQueen
Re: Adj cam ????
Postby Doc mx5 » Sat, 31 Mar 2012 8:54 +0000
Alrite i wudn really know much about that kinda stuff.its drive good and is nippy enough.ill leave it the way it is for now anyway.thanks for the advice anyway.
And welcome to the site
Doc mx5
Re: Adj cam ????
Postby LightningMxQueen » Sat, 31 Mar 2012 9:31 +0000
Doc mx5 wrote:Alrite i wudn really know much about that kinda stuff.its drive good and is nippy enough.ill leave it the way it is for now anyway.thanks for the advice anyway.
Hey thanks for the welcome Doc, it is possible that if you put it back onto a standard camwheel it might loose the nippyness that you are used to or if you got it dyno`d you might gain a bit but hey if it isnt broke then dont fix it, cheers
LightningMxQueen
