Where does this plug go??
Postby hoopsbhoy » Thu, 17 Jan 2013 1:52 +0000
:oops: I know this seems stupid as the bloody wire is only a couple of inches long, but for the life of me I can't find where it goes in, maybe i'm overlooking something or it routes a different way possibly. An exact location would be very handy, car seems to run fine without it.
To say its driving me mad would be an understatement.
Thanks in advance
hoopsbhoy
Re: Where does this plug go??
Postby leamyj » Thu, 17 Jan 2013 2:28 +0000
Don't worry about it.., when they make the wiring looms they usually incorporate all options, so it could be for something that you don't have..aircon? abs? etc.,
Postby hoopsbhoy » Thu, 17 Jan 2013 3:53 +0000
I was sort of thinking that alright but what put me off was I had an oil leak back there and everything was filthy yet the inside of that plug is spotless so it lead me to believ it was actually plugged in but its possible it wasn't.
hoopsbhoy
Postby charged_rs » Thu, 17 Jan 2013 8:22 +0000
thats for the oxygen sensor...4 pin on a 1.8 mk1
take a look down by the exhaust manifold and on the down pipe you should see the sensor...feel around for the wire and connect it back up
Postby hoopsbhoy » Thu, 17 Jan 2013 9:43 +0000
cheers, so there is a wire hanging somewhere, that makes a bit of sense, will have a look tomorrow.
hoopsbhoy
Postby charged_rs » Thu, 17 Jan 2013 10:23 +0000
hoopsbhoy wrote:cheers, so there is a wire hanging somewhere, that makes a bit of sense, will have a look tomorrow.
yep, while its disconnected you will be getting lousy mpg
Postby leamyj » Fri, 18 Jan 2013 9:58 +0000
charged_rs wrote:thats for the oxygen sensor...4 pin on a 1.8 mk1
Well spotted there Paul, :wink:
Postby hoopsbhoy » Fri, 18 Jan 2013 6:36 +0000
Fount it anyway, cheers. May start another thread about a very strange whirring/glug glug noise I seem to have
hoopsbhoy
Postby charged_rs » Fri, 18 Jan 2013 10:59 +0000
hoopsbhoy wrote:Fount it anyway, cheers. May start another thread about a very strange whirring/glug glug noise I seem to have
glug glug noise is usually heard after a run once you switch the engine off - new rad cap will sort it
Postby hoopsbhoy » Sat, 19 Jan 2013 12:14 +0000
Its from the back of the rocker cover and on tick over :-(
hoopsbhoy
Postby Steve » Mon, 21 Jan 2013 5:39 +0000
air bubble at the back of the head or in the heater matrix? Is your heater blowing hot all the time when set to hot?
Postby hoopsbhoy » Mon, 21 Jan 2013 9:16 +0000
I changed the coolant pipe there, so might it be something to do with that? It is blowing hot air constant though.
hoopsbhoy
Postby Steve » Tue, 22 Jan 2013 12:34 +0000
Aha! Its where I'd start anywho.
Postby hoopsbhoy » Tue, 22 Jan 2013 11:55 +0000
What exactly should I be doing though, how exactly will I go about it?
hoopsbhoy
Postby Steve » Tue, 22 Jan 2013 12:42 +0000
Take off the rad cap, make sure the car is on level ground (or nose slightly uphill), start car and let it idle until it gets to normal temp.
If this doesn't work, I'd replace the rad cap next.
