Gearbox Oil Change
Gearbox Oil Change
Postby jackmul94 » Tue, 07 Apr 2015 10:43 +0000
Hi all, bought a mk1 1991 mx5 about two weeks ago now and am not that fimiliar with them yet, got working on it yesterday and have replaced the clutch on it, I have the gearbox oil drained and was wondering whats the best oil for them and how much do they take??
Thanks in advance
jackmul94
Re: Gearbox Oil Change
Postby MX5Spares » Wed, 08 Apr 2015 6:43 +0000
1 ltr approx .Use good quality synthetic gear oil if possible but standard gear oil like 85/90 works fine either way . Open the fill plud on side of box and fill it until it runs out.Also very small amount of any ludbricating oil in turret ( in gear lever hole)as it does not mix with the gear oil.Its only for oiling gear linkage.
Postby davith501 » Wed, 08 Apr 2015 8:14 +0000
autocheck wrote:1 ltr approx .Use good quality synthetic gear oil if possible but standard gear oil like 85/90 works fine either way . Open the fill plud on side of box and fill it until it runs out.Also very small amount of any ludbricating oil in turret ( in gear lever hole)as it does not mix with the gear oil.Its only for oiling gear linkage.
2l for gearbox? ~300ml turret? Correct me if I'm wrong!
Icon
RS
Mk1
davith501
Postby davith501 » Wed, 08 Apr 2015 8:22 +0000
Castrol 75W90 GL4 is very popular and works well with mx5 transmissions. Any haulfrauds should have it.
Icon
RS
Mk1
davith501
Postby jackmul94 » Thu, 09 Apr 2015 6:07 +0000
cheers lads for the advice. took just under 2L to fill the box, shes back on the road now.
jackmul94
Postby davith501 » Thu, 09 Apr 2015 6:32 +0000
Good to hear! Enjoy the weather!
Icon
RS
Mk1
davith501
Postby MX5Spares » Thu, 09 Apr 2015 7:59 +0000
I use pump on 20ltr tin so I just fill to overflow so never exactly sure how much goes in.Once it flows out that good enough for me !!
Postby BAwagon » Sun, 17 May 2015 6:37 +0000
How do You add the extra oil for an NB 6 speed. I mean the small amount oil You add from the top for the 5 speed? Thx in advance for advice!
BAwagon
Postby davith501 » Sun, 17 May 2015 8:07 +0000
6 speed transmission share same oil for turret and the gearbox so by topping it up from the top would fill it up. 5 speed ones gearbox and turret oil is separate. Make sure not to overfill it. 6 speed takes 2l.
Icon
RS
Mk1
davith501
Postby BAwagon » Mon, 18 May 2015 10:12 +0000
THX !
BAwagon
