"mmmk... I'm going to need you to go ahead and come in Sunday... "
Re: problems logging inah, so between versions they decided to make the default "active topic off" for all the forums + categories, they are reenabled now.
"mmmk... I'm going to need you to go ahead and come in Sunday... " ![]()
![]() Re: problems logging init back!!!! having the same problem logging in. any one else ?
Re: problems logging inreally? Hmmm.. nothing has changed since the last update.
Would you mind trying this? : 1) log out, 2) clear/delete your cache/cookies, 3) press ctrl+F5 to reload the page 4) try logging back in again Thanks a mill! Steve
![]() Re: problems logging inlogged in today ok.
Re: problems logging inNice one, if it happens again let me know (or try the above?)
Thanks Steve
![]() Re: problems logging inWhat exactly is the problem? I have a high definition monitor and could barely make out the password.Why am I logged out regularly? Dosent happen elseware and is quite annoying. Rant over, sorry.
Re: problems logging inBelieve me, it does happen elsewhere and worse (we have some scripts/captcha in place to avoid the worse bit).
From my post earlier in this thread : "unfortunately it seems that several forums have been attacked in the same manner which involves a bot persistently trying to login to member's accounts. Our software catches this and after 3 attempts asks for the user to enter the letters from the image. They should get bored and move on after a few days." More details : http://www.phpbb.com/community/viewtopic.php?t=1947925 Yes, it is annoying. Long term project is to migrate the forum from phpBB to MyBB or similar.
![]() Re: problems logging insort it out lad..........
![]() Re: problems logging inYes same here, I still have to log in twice EVERY time to be able to read the general chat/runs threads. Even though after I log in at the first attempt it does tell I'm logged in ok....it's just that I cant read the first 2 threads.
This happens to me even when I'm trying to log in using work computer....I still have to log in twice. Is this problem unique to me..?? I know Steve is working hard behind the scenes. Just curious to know why. Thanks. John. 1991 BRG V spec
![]() Re: problems logging inCould those having login issues try using this link instead :
ucp.php?i=pm&folder=inbox It seems to be working for aquarian5 now. Thanks
