Re: What did you do to your MX5 today ?Maggie got new alloys. Check the pics here: http://www.mx5ireland.com/forum/viewtopic.php?p=34313#p34313
Re: What did you do to your MX5 today ?Painted the rocker cover and slam panel cover I got from Geese on here satin black and installed them
Re: What did you do to your MX5 today ?Yes very nice indeed.
Re: What did you do to your MX5 today ?nice!
Which method did you use to paint the letters in the cam cover?
Re: What did you do to your MX5 today ?the painstakingly slow cocktail stick method!!
Re: What did you do to your MX5 today ?Also did up the original rocker in silver should I fancy a change of look in the engine bay
(note cocktail sticks used in top rhs of photo) You do not have the required permissions to view the files attached to this post.
Re: What did you do to your MX5 today ?What did I do to my mx5 today? I took an angle grinder to it ( which had been stripped for parts) and now I've got a massive 3d jigsaw puzzle of a '91 mk1 mx5 1.6, red..NOT pink..... in my garden
Neighbours are not impressed
Re: What did you do to your MX5 today ?I replaced the bonnet release cable, Yeah
Now the headlights won't go down, Boo Anybody know where the relay is? 1990 BRG
What did you do to your MX5 today ?Prob a fuse not a relay, relay is pass side of engine bay by firewall under a cover iirc. Search fuse diagram on here and you Should find a translation, sure I put it up before.
Re: What did you do to your MX5 today ?Got them working. I took the console off and radio out and it must have jiggled a bad connection. What a rats nest of wires between the immobilizer and the radio I will clean it up eventually.
1990 BRG
Re: What did you do to your MX5 today ?Fixed fog lamp wiring (duff relay + wiring)
4 new tyres fitted, Uniroyal Rainsport 2 from www.blackcircles.com (they were out of stock in 205 45 R16 on camskills).
Re: What did you do to your MX5 today ?Fitted refurbished oe wheels and michelin pilot tyres, cleaned up the roof too.
Lots of jobs for tomorrow, diff bushings, timing belt kit, diff and gearbox oil, braided brake and clutch hoses and fresh brake fluid.
Re: What did you do to your MX5 today ?Took the wood trim around the gearshift off. I'm trying to figure out if I can make a replacement, fix the cracks in this one, buy a new one or find an old one for sale.
1990 BRG
Re: What did you do to your MX5 today ?Continued to pour money into my baby.....
Got a new alternator put in Replaced the brand new battery it destroyed (although that's under warrantee, so not so bad) Stripped out the 10 year old alarm system that was acting up and draining power intermittently Got a new Cobra alarm fitted at great expense..... seems good, anyone any feedback? (bit late now though!)... Discovered my clutch is on the way out Climbed Elbrus, Island Peak, Kilimanjaro, Elgon, Everest BC, Mulhacen, Elgon, Kayaked the Liffey to the Nile, swam the Liffey, the Lee & packed ten triathlons into a year... catch me blogging on: http://www.teenagates.com
Who is onlineUsers browsing this forum: No registered users and 15 guests | ||
