Re: What did you do to your MX5 today ?Have been thinking this mod might be useful : the temp gauge mod. More on it here. It might save an engine or two
Re: What did you do to your MX5 today ?How will that mod affect the operation if the gauge??
Re: What did you do to your MX5 today ?You should get an accurate reading rather than a "dumb" gauge which just has 3(ish) settings: "cold", "not overheating" and "too late".
Re: What did you do to your MX5 today ?I'm OVER Familiar with the too late setting!!
Re: What did you do to your MX5 today ?What started as a very slight petrol smell off the engine on Monday turned into 'ah... better look into it NOW' on Thursday evening when it was MUCH worse.
Found this between the fuel rail and the fuel pressure regulator ! More holes than a lace curtain. ![]() It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Whoops, perished or was it rubbing?
Re: What did you do to your MX5 today ?perished - looks like it is two layers of rubber with a weave of string or similar in between. The outer layer was peeling; the inner layer was crumbling. The pipe was buried under the inlet manifold, so not on my usual checklist. Only outward sign of problem was a very slight gassy smell last week - but I put it down to the car not being used often - and then as the week went on, the smell got stronger and stronger.
I have installed longer pipe, rerouting it above the manifold so that I can keep an eye on it. I'll have to replace the generic pipe with braided or better at some stage. Oh - the car just turned 140,000 miles (whatever that is in KMs, no idea) so it's officially now had more miles on it as a turbo than as an NA It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?I stuck my mx5 Ireland sticker on, bubbles and all
Sent from my HTC Desire using Tapatalk
Re: What did you do to your MX5 today ?Polished it, then broke the passangers window cable
Re: What did you do to your MX5 today ?Got new tyres this morni
OOh, that sounds good value Might give them a shout. J
Re: What did you do to your MX5 today ?Today I broke the timing belt.
Not pretty. About 40,000 miles on this one - surprised that it broke this early. No like, no like ! ![]() It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Ouch Frank, no other damage to the engine I hope??
Today I fitted a windblocker and power-washed the engine bay just in case someone decides to have a look under the bonnet at the Festival in Adare on Sunday I covered the K&N with a shopping bag, but managed to saturate the spark plug cavities, had to drive home on 3 cylinders and in limp mode......spent an hour drying them out..all well again. John
Re: What did you do to your MX5 today ?10 and 12mm sockets - just took the lid off. Haven't looked at it today, but wonder if I can get the crank bolt etc off without pulling the rad out. Should be do-able, no power-steering or aircon on this
Who is onlineUsers browsing this forum: No registered users and 15 guests | ||
