The biggest problem when I fix something is that I find two more things to fix and usually break some things on the way.
Re: What did you do to your MX5 today ?Genuinely my friends do not understand a car without central locking or the concept of how to lock the door on my NA. I bought a central locking kit from MX5 parts and attempted to install it over the weekend. The kit itself has very poor instructions and I have found more challenges than easy wins.
Re: What did you do to your MX5 today ?Hard top off yesterday. 9am this morning top down into town sun shining, me freezing but with a big smile on my face.
Let the topless action begin Sent from my GT-I9505 using Tapatalk
+1 for that concept! ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?Went to fit the silenced decat I got off Brian only to find out I measured mine incorrectly while squeezing under the car in the driveway.
Turns out mine is the 370 mm and not the 440 mm that I thought it was. Anyone selling a 370 mm silenced decat? I can trade for a 440 mm. Sent from my GT-I9505 using Tapatalk
Re: What did you do to your MX5 today ?more progress :
Re: What did you do to your MX5 today ?Brushed off the cobwebs in preperation for St.Patricks day
Re: What did you do to your MX5 today ?Removed the throttle-body and IAC thing for a good cleaning. Car has had an idle issue for a while, mostly sorted now !
![]() Did a big-brake conversion - renovated the calipers off my old 1.8 with new seals, etc and a good powder-coating, put new discs on, new Mintex pads and fresh brake fluid. The difference is amazing, it's a good upgrade to do on a 1.6. ![]() It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Mostly sorted? I ask because I have an idle issue.
1992 Mk1 Eunos silver
Mk2 suspension IL Motorsport bushes Mk2.5 leather seats 1.8 brake upgrade learning slowly http://www.mazdamenders.net
Re: What did you do to your MX5 today ?Yeah, idle used to fluctuate all over the place, and would sit at 2K rpm, then die down very slowly to 1K. A bit random.
Now, it's stable, but I need to adjust the idle screw to get it perfect as it dips when the lights are on, and so on. Carb cleaner is what I used, it's strong stuff - melts away varnish etc It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Thanks for the reply did you need to take it apart to clean it as I have seen some posts about just opening the front and spraying inside.
Re: What did you do to your MX5 today ?It works for some people, Yolo, but I don't know how. Having taken the thing apart, there are lots of little channels and airways, that I can't imagine how the carb cleaner would get into the crevices when the engine is running.
You could try it, nothing to lose. Also inject some carb cleaner down the idle-adjustment screw on the top of the throttle-body. It is designed to allow a metered amount of air in, so might be gummed up with oil and varnish. I have a feeling that that was what my main problem was. It's a small world after all. It's a small, small world
Re: What did you do to your MX5 today ?Replaced the manky, leaky rubber gearstick gaskets with this fancy silicon version "for race cars" from Doctor MX5 on Ebay. Have had it in the car for a year now, and it's holding up fine. I also added a bit of heatshield material from my old turbo car
Re: What did you do to your MX5 today ?As you say worth a go....
Re: What did you do to your MX5 today ?slowly getting there :
Re: What did you do to your MX5 today ?had a look at mine today in the paint shop ,about another 2 weeks and ill have her back in her new colour
Who is onlineUsers browsing this forum: No registered users and 15 guests | ||
