Postby gasha » Mon, 21 Apr 2014 12:38 +0000
Got a set of Roadster mats for the interior off ebay £20, very happy with them.
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby gasha » Mon, 21 Apr 2014 12:41 +0000
Fitted a front strut brace I got on ebay for £29.
92 S Special Black
89 Roadster Silver
gasha
Postby Steve » Mon, 21 Apr 2014 11:48 +0000
Removed passenger door fly window/support and weather strips for a bit of TLC.
The passenger electric window wasn't working, checked the wiring and while recrimping I managed to pull the power wire out of the actual motor! Gah...
Now investigating where I should connect the new power wire...
Postby davith501 » Tue, 22 Apr 2014 10:34 +0000
Last week did a bit of spring clean. Changed the roof and cleaned all drain channels , rubbers etc. Found a bucket load of water left side in the boot. Car was hit and who was repairing it didn't seal the piece of panel that holds taillight properly. A bit of silicone sorted that out. Spotted that car hasn't got bilsteins as supposed to so a call to almighty Robert helped to deal with that and new/not new bilsteins coming to the rescue(will be looking at upgrade springs soon) . De-tangoed headlights. Changed gearbox/diff oil, brake fluid. Drivers side seat foamectomy. Hopefully will receive clutch slave cylinder and gear shifter dust boot today so that will be fixed. After all that tax/insurance good wash/wax and ill be good to go. Can't wait to get back on the road!
[img]http://img.tapatalk.com/d/14/04/22/buja2y4u.jpg[/img]
Deivis
Icon
RS
Mk1
davith501
Postby [L'e$kro] » Tue, 22 Apr 2014 10:47 +0000
I've never seen one in that colour, very nice!
Nico
[L'e$kro]
Postby davith501 » Tue, 22 Apr 2014 10:55 +0000
Thanks, Nico. It's a se icon that came in that colour. After a wash it looks even better! :-)
Deivis
Icon
RS
Mk1
davith501
Postby back_in_black » Thu, 24 Apr 2014 10:56 +0000
Fitted mk2 bilsten from an 99 annirversary with cut springs. 14" bbs wheels with new uniroyal rain expert tyres, oil & filter change, new plugs and NCT passed this morning. Yippee!!
Just called into my local tyre guy and managed to crack the rear hub nuts with a really big bar so of home to change out diff.
back_in_black
Postby Steve » Fri, 25 Apr 2014 8:51 +0000
swopped out my duff pass window assembly for one from Robert (thanks again),
Its still laboring quite a bit and only going up using the switch while pulling hard on the glass (unless I swopped the wires round, then it would only go down ;-) ).
So, took out the switch
Unscrewed the bottom and popped off the cover + the switches
popped off the switch slide cover
Aha
Scraped + sanded all the black from the contacts and reassembled. Need to wire up the window motor tomorrow before I give it a go.
Postby Steve » Sun, 27 Apr 2014 11:16 +0000
Window switch back working, the motor is good but needed to swop the assemblies around to get the glass going up and down.
Also painted some stuff :
Postby aquarian5 » Sun, 27 Apr 2014 3:20 +0000
Nice one Steve.!
Postby Steve » Sun, 04 May 2014 1:11 +0000
rear lights were faded/cloudy and annoying me...
Decided to shave/sand off the lettering and polish them up.
Sanding lettering off :
Sanded with 500, 1500 and 2000 grit:
Drill with 3 inch pad + polishing compound + 2nd layer with scratch-X :
Postby AndyJF » Sun, 04 May 2014 8:20 +0000
Did the same last year. They come up realy well. Had to get the airline to clean out the dirty water that gets stuck between the reflector and reverse light incase your having the same problem.
Andy
AndyJF
Postby davith501 » Sun, 04 May 2014 9:22 +0000
Looks really good! Was wondering if anyone knows where could I source a red tint for lights. Preferred if I could just go and buy instead of ebaying. Anybody came across?
Deivis
Icon
RS
Mk1
davith501
Postby AndyJF » Sun, 04 May 2014 5:13 +0000
No but I have a roll of light smoke and dark smoke if you want them.
AndyJF
Postby davith501 » Sun, 04 May 2014 5:20 +0000
AndyJF wrote:No but I have a roll of light smoke and dark smoke if you want them.
Light smoke please. Thanks
Deivis
Icon
RS
Mk1
davith501
