gasha wrote:Fitted an independent coolant temperature gauge. Easy job.
Clean looking gauges. What are they?
Clean looking gauges. What are they? Icon
RS Mk1
Re: What did you do to your MX5 today ?I got them in from China, great quality and not expensive. See below:
http://www.ebay.co.uk/itm/KUS-Water-Tem ... 2a30536bdc 92 S Special Black
94 RS Limited Montego Blue 89 Roadster Silver
Re: What did you do to your MX5 today ?Busy Day today..
1. Engine oil changed. 2. Gear Box oil changed. 3. Rust on the boot lid sorted. 4. Tried to change the diff oil but didn't have a 23mm socket. (WTF!!) Why 23mm? 5. Cleaned and undersealed the passenger side under carriage. 6. Fitted a chassis rail to the passenger side. Phew!! After all that I had to go play a match. Few beers me thinks. 2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?Sounds like you had a great day , keep up the good work
Brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?Yeah it was a real big day and I loved every bit of it. Collecting some Koni coilovers for Robert next week looking forward to fitting them.
The chassis rail was easy fitting until I was under the car with the rail held up with one hand and all the bolts lined up, I reach for a nut and go to put one and it's too big...Argh!!! WTF!! Passenger side was easy but I'd say the drivers side will be a bit more of a challenge.. 2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?Well done
For the drivers side the main thing is to consider the brake and fuel lines , remove the brackets holding them on ,even the ones past the rail and that will allow you to slip the ss rail under the lines , then fit like the passenger side refitting the brackets to the new ss rails using self tapping screws ,might be worth pre drilling for these as it makes it a lot easier while on your back under the car ! To get the brackets back on to the lines I find the a bit of greese on the plastic parts really help . If you need a 23 mm spanner I think I have one , I'll be back at home next weekend , give a shout if your stuck Best of luck with the work Brian ]96 na Merlot edition. sold
Re: What did you do to your MX5 today ?Thanks for the input Brian..i'll certainly use it. Thanks for the spanner offer.. but I'll think I'll buy a socket..
Just bought some bits on mx5parts as they have a 10% discount on this weekend. 2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?got a new spring in on the driver's side (as its up in the air waiting on a caliper anyway)
![]() Got my caliper back from the machine shop... looks like its goosed. I've ordered a new one from http://brakeparts.co.uk/ , 83stlg incl delivery !
Re: What did you do to your MX5 today ?had another hack at the caliper (nothing to loose)
Got the remains of the old bleed screw out with a bit of cursing : ![]() And another bleed screw in : ![]() Put it back on the car and as expected... it leaked. Meh, at least I can put the car back on the ground now while I'm waiting for the new one.
Re: What did you do to your MX5 today ?Hi Steve.. why not try sealing it cement glue. That 2 pack stuff that hardens like metal. If the caliper is fubar anyway, it's worth a try.
Re: What did you do to your MX5 today ?yeah... I could with something like JB Weld... but I wouldn't be able to open it again to bleed it. Or do you mean something else?
Re: What did you do to your MX5 today ?Brakes, tyres, wheel nuts are all very important things on the car imo. Sometimes a diy fix just not worth it.
Icon
RS Mk1
Yeah you would not be able to open it again. I was thinking it would tide you over till you got the new caliper. If it's leaks brake oil onto the pads they will be fubar also. 2002 MK2.5 Sunlight Silver (sold)
Re: What did you do to your MX5 today ?new caliper arrived today, hope it get it on later (weather permitting)
Who is onlineUsers browsing this forum: No registered users and 22 guests | ||
