Postby davith501 » Wed, 15 Apr 2015 12:50 +0000
Nice! I think the rest of the day is looking pretty good, Steve! Have you looked into all of the sides? Remember I just did front left because it was seized and after a while had to do the other side for the same reason...and now think the rears giving trouble...good idea get it done in one go or same axle least...lesson learned haha..
Icon
RS
Mk1
davith501
Postby Steve » Thu, 16 Apr 2015 9:30 +0000
didn't get round to putting it on yet... Sat at the latest, weather looking great for the next few days.
Yeah, I'll be taking the other side apart too for a clean up/seal replacement, its been working fine though.
I've a feeling the front passenger side is dragging a bit too.
Postby Real Rayzor » Thu, 16 Apr 2015 10:19 +0000
How do you know if your calipers need to have work done. What are the tell tale signs?
Real Rayzor
Postby Steve » Thu, 16 Apr 2015 10:45 +0000
I first noticed mine was dragging when in stop/start traffic... it wasn't rolling smoothly to a stop, it would "grab" just before the car stopped. Also felt like the car was down on power a little bit. Checking the temp of the outside of your alloy compared to the others will tell you soon enough too.
Also, when braking, it can pull a little to one side.
Postby Real Rayzor » Thu, 16 Apr 2015 10:48 +0000
Thanks Steve.. All my wheels turn freely when up on stands but I do notice my car pulling when braking.
Real Rayzor
Postby davith501 » Thu, 16 Apr 2015 12:46 +0000
My experience if you haven't done brakes yourself they need to be done! Most common problem I find are the slider pins get seized because most of them would be greased with copper or similar anti seize stuff. Within time from dirt this usually turns into solid gunk and stops them from moving, dries out rubber etc. Use red rubber grease(RRG)!
Icon
RS
Mk1
davith501
Postby Real Rayzor » Fri, 17 Apr 2015 12:45 +0000
Thanks as usual for the great advise Devis. . Today I changed the soft top for a new (to me) one that I got off Robert (autocheck). Took about 4 hrs with some ocd cleaning.
Real Rayzor
Postby Steve » Fri, 17 Apr 2015 12:58 +0000
new caliper on, car back on the ground and v.happy to see the new spring didn't drop the rear more than where it was previously.
Need to do the other side this eve/over the weekend.
Postby Steve » Sat, 18 Apr 2015 5:53 +0000
got the other side finished yesterday evening, it sits pretty much exactly where I'd hoped it would.
The culprit :
Also started on the non-MX5 project. It needs a rewire, so out with the dash/gauges :
Postby Real Rayzor » Sat, 18 Apr 2015 9:03 +0000
Oh that looks interesting. What is it Steve.
Real Rayzor
Postby Steve » Mon, 20 Apr 2015 11:17 +0000
its a Madison Roadster, this one :
Postby barney » Mon, 20 Apr 2015 6:12 +0000
Mariner Blue....the best colour
Postby Real Rayzor » Tue, 21 Apr 2015 5:52 +0000
Oh my!! That is certainly interesting.
Real Rayzor
Postby Real Rayzor » Tue, 21 Apr 2015 5:55 +0000
Finished my chassis rails. The drivers side is a bitch compared to the passengers side. Also changed my diff oil and attempted to change my shocks.... holy crappie every nut is seized solid.. ffs.
Real Rayzor
Postby Merlot man » Tue, 21 Apr 2015 6:07 +0000
Sounds like you've been busy !
Try using a good releasing oil , I find worth "rost off " to be great ,hard to find ,I got mine in Bradshaws in port laois .
Worth also have a retail outlet in Limerick dock road I think . I really find wd40 unless for this type of task
Good luck
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
