Postby Real Rayzor » Tue, 21 Apr 2015 8:06 +0000
Will do Brian.. Thanks. .
Been scratching my head over these rx8 seats.. trying to come up with the easiest way to install..
Real Rayzor
Postby Steve » Wed, 22 Apr 2015 9:29 +0000
Postby davith501 » Wed, 22 Apr 2015 10:14 +0000
Merlot man wrote:Worth also have a retail outlet in Limerick dock road I think .
Ballysimon Rd. next to AutoGlass. While we're on topic..I found myself using them a good bit latey. They seem to have all the stuff that others don't or it's hard to find. The problem is if you need one self torquing nut don't go there...they sell boxes of them.
Icon
RS
Mk1
davith501
Postby Real Rayzor » Wed, 22 Apr 2015 2:00 +0000
Trip into the big city so!!
Real Rayzor
Postby Steve » Thu, 23 Apr 2015 10:58 +0000
so with the rear driver's side caliper replaced, the front passenger side is giving trouble. It didn't seem to be gripping the disk. I've taken the caliper off and had a look, the piston looks perfect when I pull back the protective boot, so its not rusted there. I put a piece of wood in the caliper and had someone step on the brake, the piston is definitely moving easily enough so that doesn't seem to be the problem. Any ideas?
Might just take it off and dismantle/reassemble (and try not to snap a bleed screw this time).
Postby davith501 » Thu, 23 Apr 2015 11:44 +0000
First thing comes to mind greasy pads, disk. Are pads contacting in full surface? If you say piston moving freely and isn't the problem then could be trapped air?
Icon
RS
Mk1
davith501
Postby Steve » Fri, 24 Apr 2015 10:59 +0000
actually... that might be exactly it... will see if the bleed screw will open over the weekend. Cheers
Postby davith501 » Fri, 24 Apr 2015 11:45 +0000
Oh dear, not another one! Haha.. Spray it and let it sit overnight..just in case..
Icon
RS
Mk1
davith501
Postby Merlot man » Fri, 24 Apr 2015 9:27 +0000
Passed the nct today ,happy days ,roll on the summer!
Both my front big brake calipers are sticking steve so must look at them ,either strip down and rebuild or get new ones , brake parts uk seems to have a caliper for£ 50 each which seems like good value, does anyone know if these are new or simply rebuilt ?
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby davith501 » Fri, 24 Apr 2015 9:35 +0000
Most of them are rebuild, Brian. If they'd be new the price would reflect that! Congratulations on your nct! Should meet up soon and take them for coastal drive!
Icon
RS
Mk1
davith501
Postby Steve » Sat, 25 Apr 2015 2:06 +0000
My rear One came from them. Couldn't tell if it was rebuilt or not, looks new.
I sprayed the bleed valve a couple of days ago, today I broke out the propane, heated it and cooled it a couple if times and out it came. Just waiting on my assistant to get back and ill bleed it.
Postby Steve » Sun, 26 Apr 2015 12:28 +0000
caliper bled, took it for a quick spin, it seems to be back in action.
Postby Real Rayzor » Sun, 26 Apr 2015 12:09 +0000
Excellent. I love it when a plan comes together.
Real Rayzor
Postby Yolo » Fri, 01 May 2015 12:00 +0000
MOTd taxed and the roof off for its first proper run in a few months.....
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby Real Rayzor » Tue, 12 May 2015 10:14 +0000
Remote central locking installed. No more fumbling with the key's.
Real Rayzor
Users browsing this forum: No registered users and 29 guests
