Postby Steve » Sun, 18 Oct 2015 6:10 +0000
fitted 4 new drop links which sorted out the knocking/bangs.
Postby Steve » Sun, 01 Nov 2015 11:51 +0000
The knocking was back... gah... after a few attempts I think I've found the problem. Had never heard of a tophat failing before :
Postby gasha » Mon, 02 Nov 2015 9:41 +0000
1st November 2015 Great Day For A test Drive.
92 S Special Black
94 RS Limited Montego Blue
89 Roadster Silver
gasha
Postby davith501 » Mon, 02 Nov 2015 12:48 +0000
Steve wrote:The knocking was back... gah... after a few attempts I think I've found the problem. Had never heard of a tophat failing before :
Jaysus, watched that video a dozen times.. Would say bushings, play in shock absorber, loose bolts..etc.. How did the top mount failed?..
Icon
RS
Mk1
davith501
Postby Steve » Mon, 02 Nov 2015 1:05 +0000
that is exactly what I thought too and had the wheel off a few times to tighten various bolts + recheck them.
It looks like the rubber bit in the tophat centre has perished or the bond has come away from the metal.
Did a bit of a google and it looks like its not unheard of.
Postby davith501 » Mon, 02 Nov 2015 2:59 +0000
Ahh, I see! Forgot mk1 has that rubber bit in the mounts. Your ones probably went through use reuse cycle for a bit now. Shouldn't be hard to get replacement. Have you any lying around?.. How's your new setup working out?
Icon
RS
Mk1
davith501
Postby Steve » Mon, 02 Nov 2015 5:16 +0000
new setup is great, except for the knocking in that one.
I've a spare tophat so will swop it out... soon... ish
Postby Steve » Wed, 25 Nov 2015 11:38 +0000
old tophat swopped out, no more knocking, yay.
Postby Real Rayzor » Thu, 26 Nov 2015 10:53 +0000
Nice one Steve
Real Rayzor
Postby emarkey » Thu, 26 Nov 2015 8:21 +0000
Gonna set the timing on the rebuilt engine and then make some legs for the new wang
emarkey
Postby Real Rayzor » Thu, 17 Dec 2015 1:23 +0000
New Rubber put on the fronts.. the lads had a bit of a job getting the car up. :D Eventually put it up on to a couple of blocks so then they able to get this inflatable thingy in there. They earned their money :D
Pain in ass a week before Xmas.
Real Rayzor
Postby gasha » Sat, 09 Jan 2016 10:33 +0000
Fitted a new rear lower lip to the S Special.
92 S Special Black
89 Roadster Silver
gasha
Postby andrius7 » Sun, 10 Jan 2016 10:55 +0000
andrius7
Postby Real Rayzor » Tue, 12 Jan 2016 11:55 +0000
gasha wrote:Fitted a new rear lower lip to the S Special.
Looks great.. nice tidy looking car too.
Real Rayzor
Postby Steve » Wed, 10 Feb 2016 7:36 +0000
gah, rear passenger side brake dragging again (hadn't driven the car in over 6 weeks). Regreased the slider pins (again) this eve and readjusted the caliper. Will see how it goes, NCT on Monday eve... erk
