Postby mc555 » Fri, 01 Oct 2010 12:20 +0000
I drove mine today... top down of course!
Found lose battery bracket and fixed it, the drove it some more.
mc555
Postby Steve » Sun, 10 Oct 2010 6:23 +0000
new rear brake pads + clips, tightened handbrake, no more rattling :thumleft:
had an exhaust leak to took off and resealed turbo
fixed indictor wiring, fog light and air intake temp wiring ground.
Postby mx5ash » Sun, 10 Oct 2010 6:33 +0000
Washed it, cleaned out the inside, took apart the passenger window mech and cleaned it all and re greased it. Better than it was but still a little slow compared to the drivers side after it was cleaned. Maybe the cables are stretched?
Postby JPW » Sat, 16 Oct 2010 7:00 +0000
Well, first I had to warm the oil by going for a spin with the top down.
Then I changed the oil.
Then I went for a spin with the top down.
Then I decided to change the plugs. Which I started to do before realising how far away the plugs are from the cam cover.
So I went went for a spin with the top down - to get an extension yokey so the spark plug socket could actually reach the spark plugs.
Then I changed the spark plugs.
Then I needed to check the car still worked. So I went for a spin with the top down.
It's been a very pleasant day.
:D
AKA Jeremy
Click below to check out my MX-5s in the Octane.ie garage:
Formerly 1.8 S-Special in Black
Now Cheap but Cheerful in Mariner Blue
JPW
Postby leamyj » Sun, 17 Oct 2010 12:55 +0000
Who'd have believed it?? Still able to drive top-down in mid October??
If global warming is responsible for this then throw another oak tree on the fire!!
(Tongue firmly in cheek here before, the tree-huggers have a go at me)
Postby cseaj » Sun, 17 Oct 2010 11:36 +0000
Fitted hard top for the winter. By God does it make a differance. Fitted my engine brace bar aswell. car solid as a rock. after that i changed the engine oil
Cheers
Chris
cseaj
Postby sidewaysreilly » Mon, 18 Oct 2010 6:38 +0000
finally got my EXHINTAKE mod done. Car pulls way better right up to limiter cutting in. Gonna play aroung with some different intake timing settings to get the best out of it. Well worth doing for a very cheap 10bhp. Oh, cut the valve cover too to reveal the pulleys. Looks like an old Cosworth BDA now. Pictures when i paint the pulleys.
Postby johnv » Mon, 18 Oct 2010 9:53 +0000
fitted new steering wheel and ss sills washed and polished./ and went for a spin with the roof down.
johnv
Postby sidewaysreilly » Wed, 20 Oct 2010 9:53 +0000
Postby galwaytt » Wed, 20 Oct 2010 10:44 +0000
oooh, do tell: does it work ?
Quick! free up some money for your '5 buy an energy efficient house ! One swallow does not a Summer make....neither is it long enough to put your '5 back together....
galwaytt
Postby sidewaysreilly » Fri, 22 Oct 2010 6:27 +0000
yes its the best mod ive done so far. The yanks reckon on 8-12 rwhp but theirs have less lift on the intake cams. Its well worth doing. Only works on the 1.8 tho.Takes about 2-3 hours.
Postby leamyj » Sun, 24 Oct 2010 12:29 +0000
Reached another stage in the dismantling of my beloved mk1..the front sub-frame came out. Now all that's left of it is the rear suspension and remaining body shell( minus the doors).and the rear lighting harness.
The big angle-grinder awaits!! :mrgreen:
Postby sidewaysreilly » Sun, 24 Oct 2010 11:36 +0000
Started fitting my polybushes. Drilled w/b's to take grease nipples so hopefully no sqeaking .
Postby jamesobrady » Mon, 25 Oct 2010 3:58 +0000
Took it out of the garage, and took pictures.
Bought it a couple of years ago as a rebuild project...but alas...plans have changed and emigration calls.
So...tis for sale having never gotten to use it:(
jamesobrady
Postby leamyj » Mon, 25 Oct 2010 9:28 +0000
Ah Jeremy, that's a pity. i assume it's posted in the for sale section?
Best wishes for the future, wherever it happens for you.
Last one out, turn off the lights please.
