Turbo BHP
Turbo BHP
Postby Navin » Fri, 25 Feb 2011 12:54 +0000
What kind of bhp would you get from a turbo mx5? i know a 1.8 standard 5 gives out around 136, so i would imagine a turbo would push it up over 200!! must be scary to drive one!!!! :shock:
Navin
Re: Turbo BHP
Postby twail » Fri, 04 Mar 2011 8:59 +0000
Navin wrote:What kind of bhp would you get from a turbo mx5? i know a 1.8 standard 5 gives out around 136, so i would imagine a turbo would push it up over 200!! must be scary to drive one!!!! :shock:
All depends on your setup!
Everyone will be different.
Im in the process of turboing my one now, and I know some one with the exact same set up as me, and he's putting out 236bhp.
twail
Re: Turbo BHP
Postby Steve » Mon, 07 Mar 2011 12:00 +0000
cool, what setup are you going for twail?
Navin, are you going to the Galway run? If so, I'll bring you for a spin, its fun ;-)
Re: Turbo BHP
Postby twail » Mon, 07 Mar 2011 5:30 +0000
Steve wrote:cool, what setup are you going for twail?
I'm running a megasquirt pnp with a Garret t25.
Lc-1 wideband
cast manifold modded for the t25 flange
Artech oil lines
Gizzmo boost controller
exedy 3 puck paddle clutch
1.8 torsen
Some of it is fitted, some isnt, a long process, then off for mapping by joe at tdr.ie
twail
Re: Turbo BHP
Postby Steve » Mon, 07 Mar 2011 7:16 +0000
Nice! Which manifold/downpipe did you go for?
My Lc-1 is giving me problems(again), have found it v.difficult to get running reliably, its all in the grounds apparently.
Re: Turbo BHP
Postby Navin » Mon, 07 Mar 2011 9:08 +0000
I wish i was going but my stag is the weekend after it so the timing is bad for me!!
Navin
Re: Turbo BHP
Postby twail » Thu, 10 Mar 2011 1:04 +0000
Steve wrote:Nice! Which manifold/downpipe did you go for?
Using a modified cast ebay manifold, and custom made elbow/downpipe/catback!
I've heard that the lc-1's need a good ground alright, I've had mine in for awhile, not really sure how accurate it is until its on the dyno!
twail
Users browsing this forum: Bing [Bot] and 2 guests
