Some buying advice
Some buying advice
Postby Uncle B » Sun, 21 Aug 2011 2:02 +0000
Hi all,
I joined a while ago (probably a year or so at this stage) but I've forgotten my details!
Anyway, I'm looking at buying my first '5.
I'm set on a NA but I'm not whether I should go for a 1.6 or 1.8.
As far as I know the 1.8 has better brakes and clutch and the later models has the better Torsen LSD?
I've heard that the 1.6 is a bit zestier and the power difference between the 2 isn't massive (115 vs 130)
Obviously the 1.6 will be slightly cheaper to tax (€140 or so)
I've spotted one on donedeal that takes my fancy.
I think the lip and alloy combined with the stance thanks to the coilovers really help the car look a bit more menacing and masculine. I assume the sticker/decal on the bootlid can be removed.
Just wondering is that car a V-Special as it says in the picture? I wouldn't know how to spot one.
Any other hints/tips/thoughts?
Uncle B
Re: Some buying advice
Postby Steve » Mon, 22 Aug 2011 1:52 +0000
1.6 vs 1.8
Try and get a spin both if you can, where are you based?
"Just wondering is that car a V-Special as it says in the picture? I wouldn't know how to spot one."
Here a Eunos model spotter's guide ;-)
http://ox.mx5oc.co.uk/guide_eunos.htm
Postby Uncle B » Mon, 22 Aug 2011 3:46 +0000
Hey Steve,
Cheers for the link, seems to match the description pretty well.
I think I'll see if its still available and go check it out and see what I think
I'm based in Galway btw
Thanks,
Paul
Uncle B
