any sparks amongst us?
PostPosted: Tue, 08 Jan 2013 8:11 +0000
by charged_rs
im in the process of making a spincaster
I have the motor from a 10 yr old hotpoint washing machine and was thinking about wiring this up to a dimmer switch so i could run it at variable speeds.
Can it be done ?
Re: any sparks amongst us?
PostPosted: Wed, 09 Jan 2013 12:02 +0000
by back_in_black
Hi Charged_rs
Quick answer is no.....
...unless the motor is DC but then you need to find the rectifier in the washing machine and then make sure the current rating of your dimmer can handle the load of the motor.
Chances are the motor from your washing machine is a single phase AC motor. A dimmer switch is for resistive loads like a standard bulb. To control the speed of AC motors you need a controler rated for the motor current usage. This can be expensive because to change the speed you need to change the frequency of the voltage supply.
The other option is find an AC motor with multiple windings for a selection of speeds. Each winding runs at a different speed and the controler is simpler and cheaper.
Hope this helps a bit anyway!
PostPosted: Wed, 09 Jan 2013 8:21 +0000
by sidewaysreilly
wtf is a spincaster
PostPosted: Wed, 09 Jan 2013 9:03 +0000
by charged_rs
sidewaysreilly wrote:wtf is a spincaster
http://en.wikipedia.org/wiki/Spin_casting
used for making stuff from low melt alloys / metals / thermoset plastics
PostPosted: Wed, 09 Jan 2013 9:11 +0000
by sidewaysreilly
aha, taut you were doing some dj job somewhere........
PostPosted: Wed, 09 Jan 2013 11:39 +0000
by charged_rs
sidewaysreilly wrote:aha, taut you were doing some dj job somewhere........
lol no..i'll leave that to the pill poppin , coke snortin youngsters ;) , plus i can barely mix cement let alone tunes
