Anyone have a Crankshaft Locking tool?
PostPosted: Fri, 01 Feb 2013 7:09 +0000
by Supertoucher
Hi guys,
I'm new but have been lurking for some time - picked up my mk2.5 last week.
Needs the cambelt doing and I was hoping on doing it this weekend as the weather is good, but the only thing which hasn't arrived in time is the crankshaft locking tool :(
Has anyone got one they got lend me for some beer or a few quid? I'm in the Sandyford area in Dublin.
Thanks,
Re: Anyone have a Crankshaft Locking tool?
PostPosted: Fri, 01 Feb 2013 7:45 +0000
by MX5Spares
You don't actually need a crank locking tool .Is it that you can't open crank bolt 'usually need airgun, as the pulley and block are marked so you can't go wrong and the cam pulleys are marked. If you want to call me I can talk you through it. Robert 086 8226506.Also good practice to replace waterpump and tensioners as they come as a kit.
PostPosted: Fri, 01 Feb 2013 10:48 +0000
by Supertoucher
Thanks for your response Robert - I do have all the kit incl waterpump but I heard its easiest to remove/torque up the crank bolt if you lock it. Is there another way to do it?
PostPosted: Sun, 03 Feb 2013 12:48 +0000
by rhysmate
Make one!! I bought a long flat bar and drilled holes and cut a slot.. Works a charm
