Postby Steve » Mon, 07 Sep 2009 1:21 +0000
Replaced driver's door seal, removed window slider channels and cleaned all the old gunk out, lots of it. Window going down AND up again now! Will do passenger side during the week.
Thought I'd do the simple job of replacing 2 broken bolts on the car to hold the spot lamps.. which turned out to be a 2 hour ordeal involving a broken drill bit in one of the holes. Job done now TG.
Postby Steve » Wed, 09 Sep 2009 3:26 +0000
replaced the unit behind the steering wheel that spontaniously combusted a few weeks ago.
Windows are stuck again though.. think I've sourced the problem.. the plastic guides that hold the window and run on the metal track are worn allowing too much play.
Postby franksm » Wed, 09 Sep 2009 3:35 +0000
Copper grease.... sweeeeeeeeeeet
Postby Steve » Wed, 09 Sep 2009 3:48 +0000
heh "slather"
Postby leamyj » Wed, 09 Sep 2009 6:07 +0000
I just use bog standard grease on mine, can't afford that copper stuff :mrgreen:
You should be able to source replacement plastic guides easy enough??
Did you get a new stalk assembly or did you pick up a replacement from a breakers??
Postby jaybond » Wed, 09 Sep 2009 8:39 +0000
Replaced the hose that gave out Sunday and did a radiator flush. Tomorrow the Dif oil.
1990 BRG
jaybond
Postby Stig » Wed, 09 Sep 2009 9:32 +0000
Did'nt do this today, but recently all the same -
Fitted Front and Back Carbing style tow hooks.
Front -
Back, hangin low :mrgreen:
Postby ger » Wed, 09 Sep 2009 10:43 +0000
No more AC, new FMIC, oh and lower wishbone polybushes jesus i'm sore.
Postby fabfiveferg » Wed, 09 Sep 2009 11:18 +0000
Nice one Ger. How did the FMIC go? You should have given me a shout for a hand. Was it much hasssle? Did you have to go somewhere to empty the AC tank?
Had a run in it yet?
Ollie. Saw those hooks in some of your sunday pics. nice
Postby Steve » Wed, 09 Sep 2009 11:33 +0000
leamyj wrote:You should be able to source replacement plastic guides easy enough??
Workin' on it.. think they might be specific to this kit though.. might see if I can cut a teeny strip of alu to run on the metal track inbetween the two.
leamyj wrote:Did you get a new stalk assembly or did you pick up a replacement from a breakers??
Used from boundville.
Postby anniniwa » Thu, 10 Sep 2009 2:31 +0000
Guys at work took my bumper off whilst away for weekend and fixed scuff on left bumper and re-sprayed...happy days! :D
Postby Coleslawsome » Thu, 10 Sep 2009 3:11 +0000
anniniwa wrote:Guys at work took my bumper off whilst away for weekend and fixed scuff on left bumper and re-sprayed...happy days! :D
BOOOOOOOOOOOOOOOOOOOOOOOOO!!!1!
Is this thread called:
"What did you do to your MX5 today?"
Or is it called:
"What did some random dudes at my place of employment do to your MX5 while you weren't around?"
For shame... for shame.
(I kid! I kid because I love!)
Coleslawsome
Postby Coleslawsome » Thu, 10 Sep 2009 3:13 +0000
Coleslawsome wrote:(I kid! I kid because I love!)
BTW, I was going to work on the MX5 outside our house, but... well, there was a lion.
It's a long story.
Coleslawsome
Postby anniniwa » Thu, 10 Sep 2009 9:49 +0000
No you're right, you're right :oops: :oops:
it's called;
'What did I nearly do to my wife's MX 5 today?'
:D :D :D
Postby mx5ash » Thu, 10 Sep 2009 10:41 +0000
Fitted this
Users browsing this forum: No registered users and 33 guests
