Took out the AC yesterday all except for the compressor mounting bracket, seem to remember a mention of shorter bolts or engine leaks anyone know anything about this?
AC removal question.Took out the AC yesterday all except for the compressor mounting bracket, seem to remember a mention of shorter bolts or engine leaks anyone know anything about this?
![]() Re: AC removal question.rings a bell alright.. I still have my compressor on.. 5 years after removing the AC
![]() Did you get rid of the power steering too or.. ? I've a shorter belt for it.. just never got round to doing it..
No keeping the power steering for the moment. The only bit left in the AC is the support bracket, which bolts to the block. I'll leave it there for the moment until I'm sure. I used the shorter belt for non AC cars, frees up a lot of space for the IC pipes and the big bonus is being able to use the AC rad mounting points for the support frame of the IC. Made a nice rectangular bracket from 1" L section for the horizontals and flat 1" for the verticals, welded on 4 small L brackets to bolt the IC to the frame. i'll post some pics when its all done.
![]() Re: AC removal question.Cool! My IC is held in with wire, the intercooler pipes themselves, zip ties and a bit of luck
![]() Re: AC removal question.I took of mine no problem bolts need a good fit socked
Do you mean the AC compressor mounting bracket (the big iron lump bolted to the block)?
