How do you identify a LSD.
Postby bomber5 » Wed, 18 Aug 2010 1:50 +0000
How do you identify a limited slip diff from others??
j
bomber5
Re: How do you identify a LSD.
Postby Steve » Wed, 18 Aug 2010 2:19 +0000
Hi J,
This is worth a read :
http://www.miata.net/garage/vlsd.html
Postby bomber5 » Thu, 19 Aug 2010 12:11 +0000
Thanks for the interesting read Steve.
j
bomber5
Postby sidewaysreilly » Sat, 21 Aug 2010 5:14 +0000
look thro the fill/level hole. If you see 2 vertical worm gears with spur gears meshing them together, its a torsen type 1. If you see 2 horizontal worm gears its a torsen type 2. Stay clear of the viscous type. They are crap.
