Thinking it's time to put the roof back on.
I'm looking for two frankenstein bolts.
Frankenstein boltsThinking it's time to put the roof back on.
Re: Frankenstein boltsso am i lad.......
Re: Frankenstein boltsi got a pair of bolts from mx5 parts to day . when i went to fit them. there is no recievers. i thougth there would be captive nuts or something. i cant see any way of reaching the bolts to put a nut on any one any ideas need to get this sorted as im picking up a hard top this weekend i hope. john
Re: Frankenstein boltsHi John, you should be ok without the bolts.
I've a hard top on my car for past 3 years, without bolts. The four clips hold the top in place with no difficulty.
Re: Frankenstein boltsIs there two large philips head screws there at the moment John?
You'll need to replace the inner one with the new frankenstein bolt Like this : ![]()
Re: Frankenstein boltsthere are philips head bolts in the rear holes but nothing in the front i put rubber grommets in to stop leaking
Re: Frankenstein boltsah I see, hmm, I had helicoil inserts put into a cylinder head last year by an engineering shop for small $$.
These guys might know someone local to you that could do similar : http://www.jgengineering.ie/contact_1.html
