Emergency advice needed ( air bag trouble )
Postby jack » Fri, 26 Nov 2010 1:56 +0000
Hi all
As some of you know, Ive had to replace my momo race steering wheel with an airAs some of you know, Ive had to replace my momo race steering wheel with an airbag wheel for the nct.
Ive just given up on it and its now 12.30 am. FRI....
I planned on taking it to the test centre this morning,( as my 30 day retest is nearly up) but having fitted the AB wheel and then reconnected the passenger side bag which had been unplugged, and then taken out the instrument panel, to find the bulb and holder was missing. ( temp replaced by the battery warning light )
I now find that there is a code 2 (flashing light ) warning .
I think I am right in saying this is a power / faulty module warning code. Ive checked all the connectors I can find and also the fuse box. The biggest problem is I can't find the air bag module !
My 5 is an NB 98 import.
What does the module look like ?
Where can it be found ?
Can it be re-set ? If not where can I get one in a hurry ?
Hope someone can give me a quick response
:shock: [/color]
To Feel Is To Believe !
jack
Re: Emergency advice needed ( air bag trouble )
Postby sidewaysreilly » Fri, 26 Nov 2010 2:03 +0000
hav'nt got a clue lad, sorry..............
Postby leamyj » Fri, 26 Nov 2010 9:56 +0000
If you find out what's needed and if it's on my mk2 and can be removed handily enough then you're welcome to borrow whatever it is...??
Again, I'm in Newbridge, but will be all over the place for the next few days( See other thread) do call me on 087/2656053 if I can be of assistance.
Postby jack » Fri, 26 Nov 2010 11:34 +0000
Thank you John.
jack
