Postby TeenaG » Mon, 14 Feb 2011 10:58 +0000
:wink: chuckle...
TeenaG
Postby Steve » Tue, 15 Feb 2011 3:08 +0000
Some stuff arrived in the post... I feel a techday coming on.
Added a sidelight to the new lights :
Soldered up a couple of Air Flow Meters :
And painted a cam cover :
NCT + slow puncture are next.
Postby leamyj » Tue, 15 Feb 2011 2:34 +0000
Everyone else gets valentine cards in the post, Steve gets car bits! :mrgreen:
How did you get old Mr Brennan to sponsor the paint job on the cam cover?
Re: Re: What did you do to your MX5 today ?
Postby Amri » Tue, 15 Feb 2011 6:10 +0000
leamyj wrote:Everyone else gets valentine cards in the post, Steve gets car bits!
A valentines set of driving lights and some clear repeaters is my idea of romance! :)
Sent from my HTC Desire
Amri
Postby sidewaysreilly » Tue, 15 Feb 2011 11:37 +0000
Well lads, you know what she wants.What ye all waitin for????? :twisted: :twisted:
Postby Steve » Wed, 23 Feb 2011 11:48 +0000
Changed the cambelt and waterpump
Postby Steve » Thu, 24 Feb 2011 8:13 +0000
Back together at last!
Postby hillymx » Thu, 24 Feb 2011 8:38 +0000
looking good steve!
hillymx
Postby franksm » Thu, 24 Feb 2011 8:44 +0000
Nice... by the way your rad-cap is off, it'll let the spiders in !
How is boost with all the new pipework ?
Postby Steve » Thu, 24 Feb 2011 10:03 +0000
Much better, def better "flow". Also fixed 4(!) boost leaks while I was at it, might need to retune?
Postby franksm » Thu, 24 Feb 2011 10:15 +0000
Yeah, definitely will need a tune. Time to dig out the laptop again LOL
Haven't connected mine for a couple of years, wonder does DLL work on Windows7 ?
Here, how did you discover the boost leaks ? Use a smoke wand or something ?
Postby Steve » Thu, 24 Feb 2011 11:00 +0000
Nah, they were fairly obvious when I found them.. two couplers had split on the back/underside so couldn't see them, a vacuum feed nipple had come loose + another vacuum hose had split. I just replaced all the rubber hoses + coolant hoses (nifty Kevlar things) today. Those heater hoses at the rear of the engine are difficult enough :!:
Oh, my laptop with the serial connection died, does the USB converter work do you know?
Might have to just use the Ipaq ... (A bluetooth to Android version would rock)
Postby franksm » Thu, 24 Feb 2011 11:05 +0000
Yeah, USB/serial adaptor works. Forgot about the IPAQ... must see if I still have one in my 'museum'.
I saw problematic vacuum hoses on mine too last year - bought a reel of silicon tube off ebay and just replaced everything
Postby mx5ash » Thu, 10 Mar 2011 9:53 +0000
oil change, new spark plugs and cleaned the air filter and a general check over before the weekend run.
Cleaned one alloy but it got to dark and cold to do the others, hopefully I will get the others done before I leave tomorrow evening or ill be looking for the use of your drive Steveo. :oops:
Postby Fergus » Mon, 14 Mar 2011 2:53 +0000
Nice work Steve, did you use the same paint that I used ?
Looks like a 1st class job ;)
Users browsing this forum: No registered users and 22 guests
