Users browsing this forum: Bing [Bot] and 0 guests
Moisture in bootHi All, this is our second winter with a '98 MX5 and we notice a lot of moisture inside boot lid, sweating kinda like the back of the fridge. Don't remember it being like this last year. Only thing that has changed in meantime is a new roof. Do they all do this? Thanks
Moisture in bootIs the back parcel shelf wet? Check under the carpet to see if sound proofing is wet. Also could be leaking light seals, ariel hole. What type of battery do you have?
Re: Moisture in bootMy own boot leak problem was caused by the rubber around the boot lock barrel being missing so water came in thru the keyhole. Fixed it by sealing with silicone.
Simon No more Mk1, now driving an '08 Mk3. Still fun!
Moisture in boot
hi Ash, thanks for getting back, only reading this now... Battery is a regular lead acid type.... Is this bad?
Who is onlineUsers browsing this forum: Bing [Bot] and 0 guests | ||
