Users browsing this forum: No registered users and 29 guests
What did you do to your MX5 today ?Got some huge uniroyal rainsports (or was it expert), 195/65/14. Filling out the wheelarches. Nice ride comfort though.
x-'91 1.6
x-'94 1.8
Re: What did you do to your MX5 today ?Sprayed up my inlet manifold, air valve to match my rocker cover :
![]() in the car : ![]() Installed an inlet manifold thermal insulating gasket when I was putting the manifold back on, supposed to limit heat transfer from the head to the mainfold ![]() Did the timing belt aswell, used a cam locking tool I got from Flyin Miata and a crank locking tool from Rennenmetal, made the job very striaghtforward for a novice diy mechanic! ![]()
Re: What did you do to your MX5 today ?Nice job.
Could have done with that locking tool a few weeks ago!
Re: What did you do to your MX5 today ?Would there be any chance of scanning that tool to get one made up????
Re: What did you do to your MX5 today ?Nearly ready. Out in the fresh air again after getting all her giblets put back in.
6 Speed Box. 3.9 T2 Diff. Rear Subframe completely rebuilt/repainted. 8.8 mhz crystal mod so i can use the power available at 7500rpm. S/h Mohair Hood which was good value. Billstein suspension with 200 front and 160 rear springs (old fronts) . Bipes to fit and a good wash and polish. You do not have the required permissions to view the files attached to this post. The perfection of a Car's beauty is that nothing should be there for beauty's sake.
Re: What did you do to your MX5 today ?Well she looks gorgeous Mr Reilly..........
Re: What did you do to your MX5 today ?those fm cam ninja tools are less than useful tbh, especially if you have to replace cam seals etc, i got one from fm last month along with a crank locking tool and a crank seal installer.
The crank locking tool is worth its weight in gold.
Re: What did you do to your MX5 today ?Thanks fobbsy.........
Re: What did you do to your MX5 today ?Finally got around to fitting my chassis rails today, cant wait to get the car back on the road now to see what kind of difference they make
Re: What did you do to your MX5 today ?me too lad.
Re: What did you do to your MX5 today ?What did you do with the fuel line?
I still need to sort that, was thinking of useing the original brackets and some self tappers into the rails?
Re: What did you do to your MX5 today ?thats exactly how I did it, just had to bend the bracket out a little bit :
Re: What did you do to your MX5 today ?The stainless steel is quite tough and it may be difficult to get a self tapping screw to work well. It may be easier to drill and tap the hole.
Thanks again for sorting this great purchase Steve. BTW, I bonded them in place with Tiger Seal which I'm hoping will add extra strength.. ![]()
Re: What did you do to your MX5 today ?luxury of having a MIG Welder. Roughly marked the rails in line with the origional bracket mounts. Drilled a clearance hole and tack welded a captive nut behind the rail. All mounted as origionally intended.
Re: What did you do to your MX5 today ?Fitted a set of similar type rails today, got mine from a group buy on nutz, nice day for it
![]() ![]() ![]() Hopefully will notice a little difference in the handling!
Who is onlineUsers browsing this forum: No registered users and 29 guests | ||
